Firmware version 1.1.1 and IE11
The new Firmware Version still does not work correctly in IE11.
With this new version 1.1.1 which it said it sorted the problem out in Internet Explorer 11, but it does not.
  "•Bug fixed: Socket and data length handling problems in some web browsers (e.g., ie11)
   •Modified the TCP socket state transition handler of the HTTP server routine for clarity"
Although now it does now change Led’s and relays the Page is not updated, so after changing one “ON” it will not allow you to set it “OFF”.
Hi. DaveOLW,
We are checking the problem you posted.
I’ll reply you as soon as checked.
Please refer to the next link, Cache Settings change in IE.
support.microsoft.com/en-us/kb/263070
If possible, I recommend that you use the Chrome browser.
