[From QnA] Wiz1000 not found
#1
using latest configuration tool Wiz1000 can not be found.
Wiz1000 has been configured to DHCP an can be pinged! But even ‘direct IP search’ does not show the device in configuration tool.
Pls advise…
#2
Dear customer,
Thanks for your interest in WIZ1000.
Did you use WIZ1000 before? Do you mean that the latest configuration tool is not OK, but the previous version works well? If so, may I know the latest version number and the previous version number?
If you are new, WIZ1000 has a search password “wiznet”. Please check whether you input the pwd before searching.
WIZnet
