We need to receive the data from various IP address to a device through WIZ110SR.
Wiz110SR is connected to one Server IP for TCP/IP protocol, If we need to get data from another IP address, then again we need to configure the WIZ110SR and Reboot the same.
So due to frequent rebooting the WIZ110SR cause any issue ?
Is there any other way to connect to different IP address without reboot the WIZ110SR.
If you need more connection, you have to implement the firmware of your prototype board to used WIZnet’s chip.
Max. 8 sockets are supported in WIZnet’s chip.
Refer to datasheet of W5500. [url]http://wizwiki.net/wiki/doku.php?id=products:w5500:start[/url]
