W5300에서 udp통신으로 값읽어올때요
VB.net 에서 W5300에 UDP통신으로 값을 받아오는데 bytes(128)까지는 잘 읽어오는데
bytes(132)부터는 쓰레기값을 읽어들이네요 아래는 소스코드 입니다
Private Sub find()
    ListView2.Items.Clear()
    ListView2.SelectedIndices.Clear()
    boardList.Clear()
    Dim bytes() As Byte
    Dim myLocal As New IPEndPoint(IPAddress.Parse("255.255.255.255"), CONFIG_RPORT)
    Dim myRemote As New IPEndPoint(IPAddress.Parse("255.255.255.255"), CONFIG_LPORT)
    Using send1 As New UdpClient(CONFIG_LPORT)
        Try
            bytes = System.Text.Encoding.ASCII.GetBytes("FIND")
            send1.Send(bytes, bytes.Length(), myLocal)
            send1.Client.ReceiveTimeout = 1000
            bytes = send1.Receive(myRemote)
            Do While (bytes.Length > 0)
                If (bytes(0) = Asc("f")) And (bytes(1) = Asc("i")) And (bytes(2) = Asc("n")) And (bytes(3) = Asc("d")) Then
                    Dim boardInfos As New BoardInfo
                    Dim i As Integer
                    boardInfos.mac = ""
                    For i = 6 To 11
                        If Len(Hex(bytes(i))) = 1 Then
                            boardInfos.mac = boardInfos.mac & "0" & Hex(bytes(i)) & ":"
                        Else
                            boardInfos.mac = boardInfos.mac & Hex(bytes(i)) & ":"
                        End If
                    Next i
                    boardInfos.mac = boardInfos.mac.Substring(0, Len(boardInfos.mac) - 1)
                    boardInfos.ver = bytes(4) & "." & bytes(5)
                    boardInfos.ip = bytes(12) & "." & bytes(13) & "." & bytes(14) & "." & bytes(15)
                    boardInfos.subnet = bytes(16) & "." & bytes(17) & "." & bytes(18) & "." & bytes(19)
                    boardInfos.gw = bytes(20) & "." & bytes(21) & "." & bytes(22) & "." & bytes(23)
                    boardInfos.dns = bytes(36) & "." & bytes(37) & "." & bytes(38) & "." & bytes(39)
                    boardInfos.port = (bytes(31) - 48) * 10000 + (bytes(32) - 48) * 1000 + (bytes(33) - 48) * 100 + (bytes(34) - 48) * 10 + (bytes(35) - 48)
                    Dim temp(64) As Byte
                    For i = 0 To 63
                        temp(i) = bytes(40 + i)
                    Next i
                    boardInfos.location = Encoding.Default.GetString(temp)
                    boardInfos.dc1 = bytes(104)
                    boardInfos.dc2 = bytes(108)
                    boardInfos.ch1 = bytes(112)
                    boardInfos.ch2 = bytes(116)
                    boardInfos.ch3 = bytes(120)
                    boardInfos.ch4 = bytes(124)
                    boardInfos.ch5 = bytes(128)
                    boardInfos.ch6 = bytes(132)
                    boardList.Add(boardInfos)
                    ListView2.Items.Add(boardInfos.mac)
                End If
            Loop
        Catch ex As Exception
        End Try
        send1.Close()
    End Using
End Sub
선언한 bytes는 256비트까지는 읽어야 정상인데 통신을하면 132부터 짤리네요
손을 대보려해도 코드의 문제인지 W5300칩과 통신할때 용량의 문제인지 모르겠습니다
답신 부탁드립니다…
잠시 헷갈렸네요 256비트가 아니라
1바이트로 된 bytes(128) 배열이네요 128바이트가 넘어가면 문제가 되는지 알려 주세요 ~
128KByte가 아니라 128Byte라면 메모리 문제는 아닌것 같네요…
주신 정보만으로는 해결이 어려울 것 같습니다. Wire shark로 UDP data packet을 캡쳐해 보시기 바랍니다.
감사합니다. :slight_smile:
