Hi Eugeny,
I have dumped the data of the common register as you suggested. I have dumped from address 0x0000 to 0x0036.
dump unsigned int[54] 0x00000417@Data (Hex) 0x00000417@Data
MR: [0] unsigned int 0x0000 (Hex) 0x00000417@Data
GAR: [1] unsigned int 0x00C0 (Hex) 0x00000418@Data
[2] unsigned int 0x00A8 (Hex) 0x00000419@Data
[3] unsigned int 0x0000 (Hex) 0x0000041A@Data
[4] unsigned int 0x0001 (Hex) 0x0000041B@Data
SUBR: [5] unsigned int 0x00FF (Hex) 0x0000041C@Data
[6] unsigned int 0x00FF (Hex) 0x0000041D@Data
[7] unsigned int 0x00FF (Hex) 0x0000041E@Data
[8] unsigned int 0x0000 (Hex) 0x0000041F@Data
SHAR: [9] unsigned int 0x0000 (Hex) 0x00000420@Data
[10] unsigned int 0x0008 (Hex) 0x00000421@Data
[11] unsigned int 0x00DC (Hex) 0x00000422@Data
[12] unsigned int 0x0001 (Hex) 0x00000423@Data
[13] unsigned int 0x0002 (Hex) 0x00000424@Data
[14] unsigned int 0x0003 (Hex) 0x00000425@Data
SIPR: [15] unsigned int 0x00C0 (Hex) 0x00000426@Data
[16] unsigned int 0x00A8 (Hex) 0x00000427@Data
[17] unsigned int 0x0000 (Hex) 0x00000428@Data
[18] unsigned int 0x0002 (Hex) 0x00000429@Data
IR: [19] unsigned int 0x0000 (Hex) 0x0000042A@Data
IMR: [20] unsigned int 0x0000 (Hex) 0x0000042B@Data
RTR: [21] unsigned int 0x0000 (Hex) 0x0000042C@Data
[22] unsigned int 0x0001 (Hex) 0x0000042D@Data
RCR: [23] unsigned int 0x0000 (Hex) 0x0000042E@Data
[24] unsigned int 0x000A (Hex) 0x0000042F@Data
[25] unsigned int 0x000A (Hex) 0x00000430@Data
[26] unsigned int 0x0000 (Hex) 0x00000431@Data
PATR: [27] unsigned int 0x0000 (Hex) 0x00000432@Data
[28] unsigned int 0x0000 (Hex) 0x00000433@Data
PPPALGO: [29] unsigned int 0x0000 (Hex) 0x00000434@Data
[30] unsigned int 0x0000 (Hex) 0x00000435@Data
VERSIONR: [31] unsigned int 0x0003 (Hex) 0x00000436@Data
Reserved: [32] unsigned int 0x0000 (Hex) 0x00000437@Data
[33] unsigned int 0x0000 (Hex) 0x00000438@Data
[34] unsigned int 0x0000 (Hex) 0x00000439@Data
[35] unsigned int 0x0000 (Hex) 0x0000043A@Data
[36] unsigned int 0x0000 (Hex) 0x0000043B@Data
[37] unsigned int 0x0000 (Hex) 0x0000043C@Data
[38] unsigned int 0x0000 (Hex) 0x0000043D@Data
[39] unsigned int 0x0000 (Hex) 0x0000043E@Data
PTIMER: [40] unsigned int 0x0028 (Hex) 0x0000043F@Data
PMAGIC: [41] unsigned int 0x0000 (Hex) 0x00000440@Data
INTLEVEL: [42] unsigned int 0x0000 (Hex) 0x00000441@Data
[43] unsigned int 0x0000 (Hex) 0x00000442@Data
Reserved: [44] unsigned int 0x0000 (Hex) 0x00000443@Data
[45] unsigned int 0x0000 (Hex) 0x00000444@Data
[46] unsigned int 0x0000 (Hex) 0x00000445@Data
[47] unsigned int 0x0000 (Hex) 0x00000446@Data
[48] unsigned int 0x0000 (Hex) 0x00000447@Data
[49] unsigned int 0x0000 (Hex) 0x00000448@Data
[50] unsigned int 0x0000 (Hex) 0x00000449@Data
IR2: [51] unsigned int 0x0000 (Hex) 0x0000044A@Data
PHYSTATUS: [52] unsigned int 0x0000 (Hex) 0x0000044B@Data
IMR2: [53] unsigned int 0x0027 (Hex) 0x0000044C@Data
irq union Sn_IR_REG {…} 0x00000416@Data
all unsigned int 0 0x00000416@Data
bit struct Sn_IR_REG_BITS {…} 0x00000416@Data
CON unsigned int : 1 0 0x00000416@Data bit 0
DISCON unsigned int : 1 0 0x00000416@Data bit 1
RECV unsigned int : 1 0 0x00000416@Data bit 2
TIMEOUT unsigned int : 1 0 0x00000416@Data bit 3
SEND_OK unsigned int : 1 0 0x00000416@Data bit 4
PNEXT unsigned int : 1 0 0x00000416@Data bit 5
PFAIL unsigned int : 1 0 0x00000416@Data bit 6
PRECV unsigned int : 1 0 0x00000416@Data bit 7
rsvd unsigned int : 8 0 0x00000416@Data bit 8-15
socket unsigned int 0 0x00000451@Data
tmp unsigned int 0 0x0000044D@Data
tsz unsigned int 62 0x00000450@Data
TxRdRing unsigned int 0x0383 (Hex) 0x0000044F@Data
TxRdRing2 unsigned int 6553 0x0000044E@Data
