look what you’re wrong … you must look DHCP example … and uses UDP, the ports are the 67 recorded for the server and 68 for the client.
Folder :
W5100_Appnote_DHCP\Src\inet
Source file:
dhcp.c
Function:
check_DHCP_state
You find a beautiful call at the socket function :
socket(s, Sn_MR_UDP, DHCP_CLIENT_PORT, 0x00)
And it is precisely what you need a beautiful UDP broadcast to all …
Clearly you will need:
- send in the package the number of “slave” by which you want the answer
- only one correct “slave” must understand that you want to talk to him and he alone must answer
with a round of broadcast for nSlave you can find the list of all the “slave” in network.
Remember that IP and MAC of the respondent are not in the TCP registers … are inside the packet header!
See Sn_MR_UDP select case in recvfrom function.
[url]http://www.wiznet.co.kr/wp-content/uploads/wiznethome/Chip/W5100/Software/W5100_Driver_V180(0).zip[/url]
Under folder :
W5100_DV_V180\
Source file:
socket.c
Function:
recvfrom
uint16 recvfrom(
SOCKET s, /**< the socket number */
uint8 * buf, /**< a pointer to copy the data to be received */
uint16 len, /**< the data size to read */
uint8 * addr, /**< a pointer to store the peer's IP address */
uint16 *port /**< a pointer to store the peer's port number. */
uint8 head[8];
uint16 data_len=0;
uint16 ptr=0;
if ( len > 0 )
ptr = IINCHIP_READ(Sn_RX_RD0(s));
ptr = ((ptr & 0x00ff) << 8) + IINCHIP_READ(Sn_RX_RD0(s) + 1);
switch (IINCHIP_READ(Sn_MR(s)) & 0x07)
case Sn_MR_UDP :
read_data(s, (uint8 *)ptr, head, 0x08);
ptr += 8;
// read peer's IP address, port number.
addr[0] = head[0];
addr[1] = head[1];
addr[2] = head[2];
addr[3] = head[3];
*port = head[4];
*port = (*port << 8) + head[5];
data_len = head[6];
data_len = (data_len << 8) + head[7];
read_data(s, (uint8 *)ptr, buf, data_len); // data copy.
ptr += data_len;
IINCHIP_WRITE(Sn_RX_RD0(s),(uint8)((ptr & 0xff00) >> 8));
IINCHIP_WRITE((Sn_RX_RD0(s) + 1),(uint8)(ptr & 0x00ff));
break;
case Sn_MR_IPRAW :
read_data(s, (uint8 *)ptr, head, 0x06);
ptr += 6;
addr[0] = head[0];
addr[1] = head[1];
addr[2] = head[2];
addr[3] = head[3];
data_len = head[4];
data_len = (data_len << 8) + head[5];
ptr += data_len;
break;
case Sn_MR_MACRAW :
read_data(s,(uint8*)ptr,head,2);
ptr+=2;
data_len = head[0];
data_len = (data_len<<8) + head[1] - 2;
read_data(s,(uint8*) ptr,buf,data_len);
ptr += data_len;
break;
default :
break;
IINCHIP_WRITE(Sn_CR(s),Sn_CR_RECV);
/* +20071122[chungs]:wait to process the command... */
while( IINCHIP_READ(Sn_CR(s)) )
return data_len;
