I’ve tried to activate newly purchased WIZ107SR with Configuration Tool ver 1.4.4.1.
Search window:
10.0.1.60 50001
After search was done, at the bottom of Configuration Tool window:
Find: 0 devices None devices selected
After a while, a popup window shows:
“A connection failed because the connected party did not
properly respond after a period of time, or established connection failed because connected host
has failed to respond 10.0.1.60:50001”
Hardware: Pull up resistors 10K on pins 4,6,8
LED on pin 8
Environment: Windows7 (x64), firewall is OFF, no virtual box.
Indicators:
When ethernet cable is connected, LEDs on RJ45: One is steady ON, other is blinking irregularly. LED on pin 8 is OFF.
When ethernet cable disconnected, both RJ45 LEDs OFF, LED on pin 8 blinks at 1sec rate.
Supply voltage is 3.0V.
What can I do?
It seems a very nice device.
Best regards
Goran
