Hi.
Currently I’m using the W5300 on the development board Wiz200Web.
Which uses the w5300 chip.
I wish to migrate some of the software to the chip w5200.
On the board 820IO.
The micro controller on the Wiz200web is the atmega128, meanwhile the microcontroller I will be using is the Atmega328P.
I wish to use the Rom File maker with this software to generate web pages.
I know I have to make some changes within the Types.H header file as per address’s.
But can you recommend any other changes to make to this file or general code?
Will I need more files?
