I’m unable to connect the AP which is available in my office which having with WPA2 Personal security. I am able to connect the wizfi220 module with security “NONE”, using command <AT+WA>. Could anyone suggest the commands to connect to my AP having WPA2 Personal security.
For your reference my AP details are as follows
BSSID SSID Channel Type RSSI Security
84:d4:7e:9c:53:b5, RES_Research , 11, INFRA , -55 , WPA2-PERSONA
Thank you
Hi.
There is a command log that will be able to connect to the AP having WPA2.
[quote]at+ws=wizms1
e8:fc:af:fd:a2:85, wizms1 , 09, INFRA , -56 , WPA2-PERSONAL
No.Of AP Found:1
[OK]
at+wd
[OK]
at+ndhcp=1
[OK]
at+wwpa=xxxxxxxx
[OK]
at+wa=wizms1
IP SubNet Gateway
192.168.1.179: 255.255.255.0: 192.168.1.1
[OK][/quote]
:: xxxxxxxx is my AP’s passphrase.
if you want to choose the security type. just add the at+wsec command before at+wa command.
at+wsec=n
n=0 : auto
n=1 : open
n=2 : WEP
n=4 : WPA-PSK
n=8 : WPA2-PSK(security type of your AP)
n=16: WPA2 Enterprise
