(Replace this first paragraph with a brief description of your new category. This guidance will appear in the category selection area, so try to keep it below 200 characters. Until you edit this description or create topics, this category won’t appear on the categories page.)
Use the following paragraphs for a longer description, or to establish category guidelines or rules:
Why should people use this category? What is it for?
How exactly is this different than the other categories we already have?
What should topics in this category generally contain?
Do we need this category? Can we merge with another category, or subcategory?
Hello there. Im using W5300 to send data according to MACRAW protocol. I use FPGA state machine to control W5300, everything is working and its about 57Mb/s (socket0, 1500byte packages). But if I load the same design to FPGA with power keept on it’s will become ~108Mb/s. After FPGA design had loaded W5300 reseted without violating any timings, then I do initiation steps again and then open Socket0 again. Have no idea how is it even possible, dont know why its speed become more than 100Mb/s. Also at 100Mb/s I have no data loosing, it is still 1500bytes in package and for 2.5 million packages its only 0.002% packages that are not recieved (I think thats ok for MACRAW)
The main question is ‘how does W5300 internal reset work, which parts(registers) of chip are not reseted?’
