Is it possible to control the I/Os through ethernet without accessing the web page?
Such as sending commands over the ethernet using TCP? is there an API?
Thanks
Reviv
Hi.
wiz550web is using web control. and I/O control is possible to web Server.
And using TCP. API is opensource hardware (iolibrary) refer to below URL.
wiz550web example code = github.com/Wiznet/WIZ550web
WIZnet library = github.com/Wiznet/ioLibrary_Driver
Thank you
