8 digital I/O output with easiest custom command
I need to control 8 digital outputs, both manually and/or through custom software on HOST PC via ethernet without adding any HW or SW to the remote unit, is the 550web the easiest option to control? or is it the 220web or other (not necessary web based)? such as?
Also, do I must use a card with MAC or anyother?
Thanks
Reviv
hi
wiz220web the previous version of wiz550web.
So, using wiz550web. and possible in 8 digital output.
you need parts,
  1. wiz550web
  2. LAN cable
  3. base board
  4. RS232C serial port
there is MAC address inside wiz550web.
Thank you
