RX is 5volt tolerant?
Do you know if module’s RX input pin is 5 volt tolerant?
Hi…
What using module?
And please tell me detail description.
Thank you
It’s WizFi250, as this forum.
Rx is received from a processor powered with 5V. All works correctly, but… will be damaged?
Hi.
Possible.
refer to below URL and you see ‘I/O port characteristics’ tap.
You check VIL & VIH. It is 5V tolernat description.
wizwiki.net/wiki/doku.php?id=pro … 50ds:start
Thank you
I red it, in brief it reports that some i/o pins are 5 volts tolerant but there is not specified which ones.
Hi…
What is mean? “I red it, in brief it reports that some i/o pins are 5 volts tolerant but there is not specified which ones.”
I don’t understand.
You want develop for schematic ?
Thank you
