Using Sn_IR RECV bit instead of Sn_RX_RSR
I have written drivers for the W5100 chip. I use the Sn_IR RECV bit to sense when new data has been received. For UDP packets, I read the packet length (offset 6 and 7 bytes from the packet start) and with that information I process the UDP packet. I then clear the Sn_IR RECV bit by writing ‘1’. I update the Sn_RX_RD value (incrementing by the packet length, plus the 8 bytes for the UDP packet header), and finally complete the receive operation by sending the RECV command (0x40) to Sn_CR.
For the W5100, if there is more received data (either new or that was already received when I checked the Sn_IR RECV bit) the Sn_IR RECV bit is again asserted (==‘1’) after the RECV command. In this way, I can reliably use the socket receive interrupt to sense data.
The datasheet for the W5200 suggests using the Sn_RX_RSR register to determine when data has been received. It specifically points to potential problems using Sn_IR RECV. Does the W5200 function differently than the W5100 in this way? Am I correct that if I do not process all received data, or if new data arrives during processing, after the RECV command is sent, Sn_IR RECV bit will again be set?
Hi, ags.
W5100 and W5200 are same structure. So receiving process should be same.
And when receive data if you do not process prior received data, Sn_IR(recv) isn’t set as 1 after clearing Sn_IR(recv) bit automatically. It is overlapped.
So, we recommend using Sn_IR and Sn_RX_RSR both.
Best regards.
