WIZ107SR uart to server
Just got the first WIZ107SR, it has version 4.04 on it (I didn’t update it yet).
I’ve configured it using the configuration tool to my server ,port, uart etc’.
When I reset the device I get I see on the terminal (I’ve tried both tera-term & putty):
LGWIZ107SR:VER4.04:STARTED
LGSEGCP:TCP:STARTED
LGSEGCP:UDP:STARTED
LGDHCP:UPDATE
LGMAC:00.08.DC.1F.31.61
LGGW:192.168.1.1
LGSN:255.255.255.0
LGIP:192.168.1.115
LGSEGCP:TCP:STARTED
LGSEGCP:UDP:STARTED
LGSEG:CONNECTED
In the server log I can see the same output.
Yet when I type data in the terminal connected via uart I don’t see the data on the server log.
It seems that the server doesn’t receive any new data - I’ve confirmed that using wireshark.
The other direction is OK I can type anything in the server response & it will be printed on the terminal.
What am I’m doing wrong?
hi.
please refer to below URL
wiznet.co.kr/wp-content/uplo … _V171E.pdf
It is User’s manual.
check the below menu.
  1. Getting Started
    2.1 Config tool description.
Thank you
