Hi!,
I’ve a Problem.
When I’m trying to connect the Wizfi210 to an IPhone Hotspot with a WPA2 encryption an error occur.
But when I am opening a Hotspot with an Android Phone with a WPA 2 encryption, the WI-FI Module can connect to the Hotspot and get a IP-Address from the DHCP Server.
I am using the following comands to configure the WIFI module, so it can connect to an AP with WPA2 encryption.
At
[OK]
AAttee00
[OK]
AT+Xdum=0
[OK]
AT+BDATA=1
[OK]
AT+WD
[OK]
AT+NDHCP=1
[OK]
AT+WPAPSK= , // SSID+ Password generate a PSK-key
AT+WA=IPHONESSID
[ERROR]
So my question is :
Did I forgot to configure something for the iPhone AP ? , or does the Wizfi210 doesn’t support iPhone Access Points.
Thanks for helping.
Best regards,
WOLF
