Issue with W7500P Peripheral Example - WZTOE
I found at the example of W7500P - WZTOE , still Use PB_14 and PB_15 for MDIO, but W7500P datasheet and Reference manual do not define these two pins, which exist only at W7500, I hope to get help for this issue.
Thanks,
Ed
Hi.
What example in WIZTOE?
http? , Loopback??
Thank you
I only looked at examples of DHCPClient and LoopbackTest.
At the example of WZTOE_DHCPClient:
mdio_init(GPIOB, MDC, MDIO ) is called by main(). The following code are from subroutine mdio_init():
PAD_AFConfig(PAD_PB, GPIO_Pin_MDIO, PAD_AF1);  // GPIO_Pin_MDIO = GPIO_Pin_15
PAD_AFConfig(PAD_PB, GPIO_Pin_MDC, PAD_AF1);   // GPIO_Pin_MDC = GPIO_Pin_14
But when I refer to datasheet and reference manual of W7500P, which do not define the alternate funtion of PB_14 and PB_15 Pin.
The following code also are from main(), I could n’t find the definition of pad control register with address of (0x41003070) and (0x41003054).
ifdef W7500P
*(volatile uint32_t *)(0x41003070) = 0x61;
*(volatile uint32_t *)(0x41003054) = 0x61;
#endif
So, I hope to get support and advice, Please!!!
