Curious if there is any example code on how to successfully send data via a web-page to one of these devices?
I picked up a WIZ110SR with the hopes of being able to control PTZ cameras on the other end via a custom web-page interface and while I can hunt around for a general solution, I thought I would ask here in case WIZnet already has a template HTML solution they can provide?
So my question is can not the WIZ100R do this? I bought one under the impression that it could.
I’d like to be able to place the WIZ100R next to a Serial controlled PTZ camera and send PTZ serial commands from a remote location to the WIZ100R via TCP which in turn spits that out it’s serial port to the camera. Is this not what the WIZ100R can do? I see a TCP/IP connection, a Serial connection, an IP address… all that seems to be missing is some example code on how to send serial commands to the TCP/IP socket?
Confused. I am not using serial to send commands, I’m using Ethernet:
Computer → Switch 1 <-> WIZ100SR <-> Serial interface to PTZ Camera
So from Computer, I want to utilizing (this is my question, is there sample code) sending serial commands through a TCP/IP socket connected to the WIZ100SR say in the other room so it in turn sends those SERIAL PTZ commands to the camera connected to it.
By all design, this box looks like it should do this right? Isn’t that what this box is?
