i have a problem to connect to my AP when i use the character “,” (ASCII 0x2C) in the password !
if i set the password to “123456789”, no problem
if i set “123456,789”, i successful connect to my AP !
after checking the AT+WSET command, i think that there is maybe a problem with the module that do not support the “,” in the command …?
==> how to solve this issue please ?
what is that 1.0.4.9 version !!?? how many different non official and non released version you use !!??
we can’t use non official released version, so if you consider 1.0.4.9 as stable, please release it !!
(same problem for the 1.0.5.1 version you provide us for the problem of multi client access )
if we use 1.0.5.1, what guaranty us that new feature of 1.0.4.9 are included ?..
if we use 1.0.4.9, the multi client feature is not added too …
that’s not a good practice !
so what is the solution for the “,” character and the 1.0.4.2 fw ??
no solution ?.. bug that is not tracked anywhere …
we already release a lot of products with 1.0.4.2 version … do we need to plan to update all products …?
inform our customers that “,” char is not possible … they need to update all there equipments because our equipment is not conform to the standard ?
When Some functions are added in F/W, it cause F/W version to increase.
Upgrading F/W to Higher version, It include the feature of lower F/W.
Higher version of F/W provides backwards compatibility with lower F/W.
And the function you want(about “,”) supports the F/W 1.0.4.9 or higher.
as you know, the feature for multi client access can use the F/W 1.0.5.1 or higher.
(1.0.5.1 version is made from your opinion.)
