I’ve also designed and built in 33 Ohm damping resistors in front of a HY931147C magjack and facing link issues with Netgear GS724T switch.
The switch port is just fluctuating between up and down states according to the switch log quite rapidly (2-3 secs)
Sometimes it stays up for a while, but not more than for an hour.
After disabling spanning tree* (enable “FastLink” in Netgear terminolgy) on the switch port connected to W5500 the link became stable.
In GS724T the setting can be found on GUI: Switching / STP / Advanced CST Port configuration or on CLI:
interface g4
spanning-tree edgeport
This thread is very helpful and just wanted to contribute with my findings.
*edit:
according to Netgear manual enabling FastLink does not disable STP on the port:
“If Fast Link mode is enabled for a interface, the Port State is automatically placed in the Forwarding state when the port link is up. Fast Link optimizes the STP protocol convergence.”
I’m trying to integrate the w5500 directly on my product. I’ve successfully used the 5500io module. I can’t get my w5500 to link to a router. The w5500io module does.
I’m using the same magnetics as the 5500io, I’ve copied the schematic. I’ve checked signals by sending a 10% 5MHZ signal on the orange / green pairs, and get identical results with a scope on pins 1,2 and 5,6 of the w5500. I do have 25MHZ clock into the w5500.
I’ve done hardware reset, software reset, sent IP, Sub, Gate, MAC. What should I send for PHYCFGR and MODE_REG? What am I missing?
What does the PIC processor on the 5500io module send the w5500 on power up?
