Do you have any information on how the AJAX and Wiz550Web interact? I am using your demo pages and editing them but trial and error is a slow proccess. I was hoping that you had some documentation that explains the the interaction.
Thanks!
Thanks!
Hi.
Sorry… We not have AJAX information documents…
Web have just simple documents.
refer to below URL. It is simple document. (web page)
wizwiki.net/wiki/doku.php?id=pro … 0webgsg_en
And refer to below URL. It is web page download URL.
Thank you
Thanks for your reply. Since there is no information on how your application works, I was hoping that you could answer a few questions for me?
(index):265 POST 192.168.11.100/dout.cgi net::ERR_CONNECTION_REFUSED
AJAX.doPost @ (index):265
(anonymous function) @ (index):390
I was also wondering how I can check the state of a pin, whether or not is is Hi or low?
Thanks!
function postdataPinState(pinNumber,pinState){
var p=pinNumber;
var v = pinState;
dout_timer=setTimeout(function(){
if(dout && dout.abort){dout.abort();}
dout=new AJAX(‘dout.cgi’,function(t){
try{eval(t);}catch(e){alert(e);}
dout.doPost(‘pin=’+p+‘&val=’+v);
},300);
function postdataPinDir(pinNumber,pinDirection){
var p=pinNumber;
var v = pinDirection;
dout=new AJAX(‘dir_change.cgi’,function(t){
try{eval(t);}catch(e){alert(e);console.log(t);}
dout.doPost(‘pin=’+p+‘&dir=’+v);
},300);
function myDelay(myDelayTime){
for(var i=0; i<myDelayTime;){
i++;
function setAddrToVersion(){
postdataPinState(10,0);
postdataPinState(11,0);
postdataPinState(12,0);
postdataPinState(13,0);
function setDataBusToInput(){
postdataPinDir(0,1);
myDelay(1000);
postdataPinDir(1,1);
myDelay(1000);
postdataPinDir(2,1);
myDelay(1000);
postdataPinDir(3,1);
myDelay(1000);
postdataPinDir(4,1);
myDelay(1000);
postdataPinDir(5,1);
myDelay(1000);
postdataPinDir(6,1);
myDelay(1000);
postdataPinDir(7,1);
function setDataBusToOutput(){
postdataPinDir(0,2);
myDelay(1000);
postdataPinDir(1,2);
myDelay(1000);
postdataPinDir(2,2);
myDelay(1000);
postdataPinDir(3,2);
myDelay(1000);
postdataPinDir(4,2);
myDelay(1000);
postdataPinDir(5,2);
myDelay(1000);
postdataPinDir(6,2);
myDelay(1000);
postdataPinDir(7,2);
function getRevisionNum(){
setTimeout(setDataBusToInput(),1500*1);
setAddrToVersion();
//setDataBusToOutput();
I would also like to know how to read the status of an actual pin without having to check the html alias/name.
Thanks!
Nevermind… as if you were actually working on it.
There are two ways to do what I wanted.
use JQuery and the when() then() methods
simply make ajax synchronus (this is what I used)
function AJAX(url, callback)
var req = AJAX_init();
req.onreadystatechange = AJAX_processRequest;
function AJAX_init() {
if (window.XMLHttpRequest) {
return new XMLHttpRequest();
} else if (window.ActiveXObject) {
return new ActiveXObject('Microsoft.XMLHTTP');
function AJAX_processRequest() {
if(req.readyState == 4) {
if(req.status == 200) {
if(callback)
callback(req.responseText);
this.doGet = function() {
req.open('GET', url, false); // set this to false for synchronous behavior
req.send(null);
this.doPost = function(body) {
req.open('POST', url, false); // set this to false for synchronous behavior
req.setRequestHeader('Content-Type',
'application/x-www-form-urlencoded');
req.setRequestHeader('ISAJAX','yes');
req.send(body);
