uint32 getSn_TX_WRSR(SOCKET s)
uint32 tx_write_size=0;
tx_write_size = IINCHIP_READ(Sn_TX_WRSR(s))& 0xffff;
tx_write_size = (tx_write_size << 16) + (IINCHIP_READ(Sn_TX_WRSR2(s))& 0xffff);
return tx_write_size;
void setSn_TX_WRSR(SOCKET s, uint32 size)
uint32 check;
IINCHIP_WRITE(Sn_TX_WRSR(s), (uint16)(size >> 16));
IINCHIP_WRITE(Sn_TX_WRSR2(s), (uint16)size);
check = getSn_TX_WRSR(s);
uint32 send(SOCKET s, uint8 * buf, uint32 len)
uint8 status=0;
uint32 ret=0;
uint32 freesize=0;
/* #ifdef DEF_IINCHIP_DBG
uint32 loopcnt = 0;
PrintString("%d:send()\r\n",s);
#endif
ret = len;
if (len > getIINCHIP_TxMAX(s)) ret = getIINCHIP_TxMAX(s); // check size not to exceed MAX size.
* \note if you want to use non blocking function, “do{}while(freesize < ret)” code block
* can be replaced with the below code. \n
* \code
* while((freesize = getSn_TX_FSR(s))==0);
* ret = freesize;
* \endcode
// NOTE : CODE BLOCK START
do
freesize = getSn_TX_FSR(s);
status = getSn_SSR(s);
/ #ifdef DEF_IINCHIP_DBG
PrintString(“%d : fsize=%ld\r\n”,s,freesize);
if(loopcnt++ > 0x0010000)
PrintString(“%d : freesize=%ld,status=%04x\r\n”,s,freesize,status);
PrintString(“%d:Send Size=%08lx(%d)\r\n”,s,ret,ret);
PrintString(“MR=%04x\r\n”,((vuint16)MR));
loopcnt = 0;
#endif
if ((status != SOCK_ESTABLISHED) && (status != SOCK_CLOSE_WAIT)) return 0;
} while (freesize < ret);
// NOTE : CODE BLOCK END
wiz_write_buf(s,buf,ret); // copy data
loopcnt=0;
#endif
if(!check_sendok_flag[s]) // if first send, skip.
while (!(getSn_IR(s) & Sn_IR_SENDOK)) // wait previous SEND command completion.
if(loopcnt++ > 0x010000)
#ifdef _DEBUG_LANTEST
PrintString(“%d:Sn_SSR(%04x)\r\n”,s,status);
#endif
loopcnt = 0;
#endif
if (getSn_SSR(s) == SOCK_CLOSED) // check timeout or abnormal closed.
PrintString(“%d : Send Fail. SOCK_CLOSED.\r\n”,s);
#endif */
return 0;
setSn_IR(s, Sn_IR_SENDOK); // clear Sn_IR_SENDOK
else check_sendok_flag[s] = 0;
// send
setSn_TX_WRSR(s,ret); //Data 갯수지정
setSn_CR(s,Sn_CR_SEND); //Data를 보내는 지령
return ret;
상기프로그램으로 Data 전송시 29개의 Data를 보내는데 보내고자하는 Data 29개 이후로 0x00이 많이 보내 집니다.
29이후로 몇개의 data가 더 보내지는지는 확인 중입니다.
setSn_TX_WRSR에서 보내는 Data 숫자는 확인하였습니다.
빠른 답변 부탁드립니다.
개인정보보호가 필요하지만 너무 급해서 전화 번호를 남깁니다. 010-2423-6357
