I have W5500 setup and running. I checked the MAC and IP and the configuration is correct, also when I try to ping the IP of the W5500 I get the reply, so I’m guessing the W5500 is up and running.
Now I have the issue that I want to send some packets to the UDP server, and I’m trying to use sendto(SOCK_UDP, data, count, ip, port)
However, It looks like I’m doing something wrong… Can someone please post an explanation on how to send UDP packets to certain IP:PORT or point me to the documentation where I can learn more about this?
