[Solved]Arduino DUE ioShield, IDE Greater than 1.5
Hello
I have seen that Arduino DUE is compatible with ioshield-A.
In the Git Hub page talks about Arduino IDE 1.5.x… is it also compatible with higher IDE’s as 1.6?
Thanks
Hi.
If you using IDE version 1.5.x up, then you use 1.5.x folder.
Arduino library below link
github.com/Wiznet/WIZ_Ethernet_Library
Thank you
