Setting data rate and channel on the Wizfi210
I want to set the channel and data rate on Wizfi210 module.I was reading its programmers interface manual and found this AT command.
AT+UNSOLICITEDTX Format
AT+UNSOLICITEDTX=,,,,, ,,
Could someone please give an example as to how to use this command?
If you want to change the channel and data rate, I suppose two below command will be more helpful than that command.
  • AT+WAUTO=,,[],[channel]
    Note that mode value 1(Ad-hoc mode) and 2(Limited Ap mode) is possible.
  • AT+WRATE=
    ex)
    AT+WRATE=0 (Auto)
    AT+WRATE=2 (1MBPS)
    AT+WRATE=4 (2MBPS)
    AT+WRATE=11 (5.5MBPS)
    AT+WRATE=22 (11MBPS)
Thank, best regards
Can you give an example for this
[quote]- AT+WAUTO=,,[],[channel]
Note that mode value 1(Ad-hoc mode) and 2(Limited Ap mode) is possible.[/quote]
I’m so sorry for late reply.
AT+WAUTO= ,,[BSSID],[channel]
  • Sets WiFi parameters to be used for Auto Connect.
  • Mode is 0 for Infrastructure, 1 for Ad-hoc mode and 2 for Limited-AP mode.
: Operating mode
: SSID of AP which WizFi210 will associate with
[BSSID] : BSSID of AP which WizFi210 will associate with.
[channel] : Channel of AP which WizFi210 will associate with.
Thank, best regards
Cliff AT+WRATE=? can only be used to know what is the current transmit rate but not to set it.Please let me know as to how can I set the data rate? When I did AT+WRATE=2 i got an error but when I did AT+WRATE=? I got 0. I also did this “AT+UNSOLICITEDTX=,1,” but I get ERROR: INVALID INPUT.
