I am trying to get the Wizfi210 to work with arduino Due but no luck.Could someone tell me what could be going wrong in my code. Unlike other arduinos I am not able to set the SPI to 125khz.What is the maximum SPI speed for Wizfi210?
WizFi210 Arduino test code
Circuit:
WizFi210 connected to Arduino via SPI
RST: pin 2 // Output
DRDY: pin 3 // Input
CSB: pin 4 // output
MOSI: pin 11 // output
MISO: pin 12
SCK: pin 13 // out
Created 15 May 2012
by Jinbuhm Kim (jbkim@wiznet, Jinbuhm.Kim@gmail.com)
// WizFi210 communicates using SPI, so include the SPI library:
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <SPI.h>
#define DHCP_ENABLE 1
const byte SPI_ESC_CHAR = 0xFB; /* Start transmission indication */
const byte SPI_IDLE_CHAR = 0xF5; /* synchronous IDLE */
const byte SPI_XOFF_CHAR = 0xFA; /* Stop transmission indication */
const byte SPI_XON_CHAR = 0xFD; /* Start transmission indication */
const byte SPI_INVALID_CHAR_ALL_ONE = 0xFF; /* Invalid character possibly recieved during reboot */
const byte SPI_INVALID_CHAR_ALL_ZERO = 0x00; /* Invalid character possibly recieved during reboot */
const byte SPI_LINK_READY = 0xF3; /* SPI link ready */
#define SSID "Tenda_47F130" // SSID of your AP
#define WPA_PASS "12345678" // WPA Password
#define Infrastructure 0//0
#define Ad_hoc 1//1
#define Client_Mode 0
#define Server_Mode 1
#define Protocol_UDP 0//0
#define Protocol_TCP 1//1
// for static IP address
unsigned char IP[4] = {192, 168, 88, 123};
unsigned char Sub[4] = {255, 255, 255, 0};
unsigned char Gw[4] = {192, 168, 88, 1};
unsigned char SIP[4] = {192, 168, 88, 228};
unsigned int ListenPort = 5000;
unsigned int ServerPort = 5000;
// pins used for the connection with the WizFi210
//const int rstPin = 2;
const int dataReadyPin = 3;//gpio19 on wizfi210 module
const int chipSelectPin = 4;
//gpio21 - SFAC_RST,FAC_RST button is connected to gnd for hardware reset
boolean Wifi_setup = false;
void setup() {
Serial.begin(9600);
Serial.println("\r\nSerial Init");
// initalize the data ready and chip select pins:
pinMode(dataReadyPin, INPUT);
pinMode(chipSelectPin, OUTPUT);
//pinMode(rstPin, OUTPUT);
// start the SPI library:
SPI.setDataMode(SPI_MODE0);
SPI.setBitOrder(MSBFIRST);
//SPI.setClockDivider(4,SPI_CLOCK_DIV128); //
SPI.setClockDivider(4, 128);
SPI.begin(4);
// digitalWrite(chipSelectPin, HIGH);
// digitalWrite(rstPin, HIGH);
//Serial.println("Wi-Fi Reset");
//digitalWrite(rstPin, LOW);
//delay(500);
//digitalWrite(rstPin, HIGH);
delay(1000); //
Serial.println("Wi-Fi Init");
Init();
Serial.println("Wi-Fi Init Complete");
void loop() {
byte tmp;
if (Wifi_setup == true)
//if(1)
// if there is data from Wi-Fi side.
tmp = WizFI210_Read_Byte();
if ((tmp != SPI_IDLE_CHAR) && (tmp != SPI_INVALID_CHAR_ALL_ZERO) && (tmp != SPI_INVALID_CHAR_ALL_ONE)){
Serial.print(char(tmp));
// if the connection is established, incoming serial data sent to the peer.
if (Serial.available() > 0) {
WizFI210_Write_Byte(Serial.read());
/*while(1)
WizFI210_Write_Byte('R');
delay(100);
Serial.println("sent");
byte WizFI210_Read_Byte() {
byte result;
//digitalWrite(chipSelectPin, LOW);
result = SPI.transfer(4,0);
//digitalWrite(chipSelectPin, HIGH);
return(result);
unsigned int WizFI210_Read_Buf(byte * buf)
int idx = 0;
byte tmp;
byte chk = 0;
while(digitalRead(dataReadyPin) == HIGH) {
if ((tmp != SPI_IDLE_CHAR) && (tmp != SPI_INVALID_CHAR_ALL_ZERO) && (tmp != SPI_INVALID_CHAR_ALL_ONE)) {
if (tmp == SPI_ESC_CHAR) {
chk = 1;
}else {
if (chk == 1) {
chk = 0;
tmp = tmp ^ 0x20;
buf[idx++] = tmp;
return(idx);
byte SpiByteStuff(byte *thisValue)
if( (SPI_ESC_CHAR == *thisValue) ||
(SPI_XON_CHAR == *thisValue) ||
(SPI_XOFF_CHAR == *thisValue) ||
(SPI_IDLE_CHAR == *thisValue) ||
(SPI_INVALID_CHAR_ALL_ONE == *thisValue) ||
(SPI_INVALID_CHAR_ALL_ZERO == *thisValue)||
(SPI_LINK_READY == *thisValue))
{ // Byte stuffing is required
*thisValue = *thisValue ^ 0x20;
return 0x01;
else
return 0x00;
void WizFI210_Write_Byte(byte thisValue)
if (SpiByteStuff(&thisValue)) {
// Byte stuffing is required.
SPI.transfer(4,SPI_ESC_CHAR);
SPI.transfer(4,thisValue);
void WizFI210_Write_Buf(byte *s)
while (*s != '\0')
if (SpiByteStuff(s)) {
SPI.transfer(4,*s);
s ++;
delay(10);
byte Check_OK(byte * buf, unsigned int TimeOut)
unsigned int idx = 0;
unsigned int t=0;
byte tmp;
char * ret = NULL;
while(1) {
buf[idx++] = tmp;
//if (idx > sizeof(buf)) idx = 0;
if (tmp == ']') break;
if (t++ > TimeOut) {
// Serial.println("Time out");
break;
delay(10);
// flush
delay(10);
ret = strstr((char *)buf, "[OK]");
if (ret != NULL) {
return 1;
} else {
return 0;
byte IsCommandMode()
byte msg[]="AT\r\n";
WizFI210_Write_Buf(msg);
memset(msg, '\0', sizeof(msg));
return(Check_OK(msg, 2000));
void Init(void)
byte Msgbuf[68];
byte key;
Serial.println("Send Sync data");
WizFI210_Write_Byte(SPI_IDLE_CHAR);
delay(1000);
while(1) {
key = WizFI210_Read_Byte();
if ((key != SPI_IDLE_CHAR) && (key != SPI_INVALID_CHAR_ALL_ZERO) && (key != SPI_INVALID_CHAR_ALL_ONE)) {
// debug
//Serial.print(char(key));
if (digitalRead(dataReadyPin) == LOW) break;
delay(10);
Serial.println("Ok");
// Send AT
Serial.print("\r\nSend AT");
sprintf((char *)Msgbuf, "AT\r");
WizFI210_Write_Buf(Msgbuf);
memset(Msgbuf, '\0', sizeof(Msgbuf));
if (Check_OK(Msgbuf, 2000)) Serial.print(" : Success");
else {
Serial.println("\r\nSend 2nd AT");
if (Check_OK(Msgbuf, 2000)) Serial.println(" : Success");
else Serial.println(" : Error");
if (Setup_WiFi() == true) {
Wifi_setup = true;
Serial.println("\r\nConfiguration OK");
}else {
Wifi_setup = false;
Serial.println("\r\nConfiguration fail");
boolean Setup_WiFi(void)
byte Msgbuf[128];
Serial.println("\r\nTest Command");
sprintf((char *)Msgbuf, "AT+WD\r");
Serial.print((char *)Msgbuf);
if (Check_OK(Msgbuf, 10000)) Serial.println(" : Success");
// AT+WAUTO
sprintf((char *)Msgbuf, "AT+WAUTO=0,%s\r\n", SSID);
// Serial.print((char *)Msgbuf);
if (Check_OK(Msgbuf, 1000)) Serial.println(" : Success");
// AT+WAUTH
sprintf((char *)Msgbuf, "AT+WAUTH=%d\r\n",0);
// AT+WWPA
sprintf((char *)Msgbuf, "AT+WWPA=%s\r\n",WPA_PASS);
#ifdef DHCP_ENABLE
// AT+NDHCP
sprintf((char *)Msgbuf, "AT+NDHCP=%d\r\n",1);
#else
// AT+NDHCP
sprintf((char *)Msgbuf, "AT+NDHCP=%d\r\n",0);
// AT+NSET
sprintf((char *)Msgbuf, "AT+NSET=%d.%d.%d.%d,%d.%d.%d.%d,%d.%d.%d.%d\r\n",
IP[0],IP[1],IP[2],IP[3],Sub[0],Sub[1],Sub[2],Sub[3],Gw[0],Gw[1],Gw[2],Gw[3]);
#endif
// AT+NAUTO
sprintf((char *)Msgbuf, "AT+NAUTO=%d,%d,,%d\r\n",Server_Mode, Protocol_TCP, ListenPort);
// AT+XDUM
sprintf((char *)Msgbuf, "AT+XDUM=%d\r\n", 0); // 1: Uart message is disable, 0: enable
// MAC address writing
sprintf((char *)Msgbuf, "AT+NMAC=00:08:DC:18:76:57\r\n");
// ATA
sprintf((char *)Msgbuf, "ATA\r\n");
//Serial.print((char *)Msgbuf);
if (Check_OK(Msgbuf, 20000)) {
return true;
else {
return false;
