No voltage on Antenna with arduino even when transmitting
I am trying to make the Wizfi210 send data but I am not able to get any voltage on the antenna.Here is my code:
 WizFi210 Arduino test code
 Circuit:
 WizFi210 connected to Arduino via SPI
 RST: pin 2  // Output
 DRDY: pin 3  // Input
 CSB: pin 4  // output
 MOSI: pin 11  // output
 MISO: pin 12
 SCK: pin 13  // out
 Created 15 May 2012
 by Jinbuhm Kim  (jbkim@wiznet, Jinbuhm.Kim@gmail.com)
// WizFi210 communicates using SPI, so include the SPI library:
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <SPI.h>
#define DHCP_ENABLE 1
const byte SPI_ESC_CHAR  = 0xFB;       /* Start transmission indication */
const byte SPI_IDLE_CHAR = 0xF5;       /* synchronous IDLE */
const byte SPI_XOFF_CHAR = 0xFA;       /* Stop transmission indication */
const byte SPI_XON_CHAR = 0xFD;        /* Start transmission indication */
const byte SPI_INVALID_CHAR_ALL_ONE = 0xFF;    /* Invalid character possibly recieved during reboot */
const byte SPI_INVALID_CHAR_ALL_ZERO = 0x00;    /* Invalid character possibly recieved during reboot */
const byte SPI_LINK_READY = 0xF3;     /* SPI link ready */
#define SSID     "Tenda_47F130"        // SSID of your AP
#define WPA_PASS  "12345678"         // WPA Password
#define Infrastructure  1//0
#define Ad_hoc    0//1
#define Client_Mode 1
#define Server_Mode 0
#define Protocol_UDP  1//0
#define Protocol_TCP  0//1
// for static IP address
unsigned char IP[4]     = {192, 168, 88, 123};
unsigned char  Sub[4]           = {255, 255, 255, 0};
unsigned char  Gw[4]    = {192, 168, 88, 1};
unsigned char  SIP[4]           = {192, 168, 88, 228};
unsigned int ListenPort = 5000;
unsigned int ServerPort = 5000;
// pins used for the connection with the WizFi210
//const int rstPin = 2;
const int dataReadyPin = 3;
const int chipSelectPin = 4;
boolean Wifi_setup = false;
int cnt=0;
void setup() {
  Serial.begin(115200);
  Serial.println("\r\nSerial Init");
  // initalize the  data ready and chip select pins:
  pinMode(dataReadyPin, INPUT);
  pinMode(chipSelectPin, OUTPUT);
  //pinMode(rstPin, OUTPUT);
  // start the SPI library:
    SPI.setDataMode(SPI_MODE0);
    SPI.setBitOrder(MSBFIRST);
    SPI.setClockDivider(SPI_CLOCK_DIV64); //
    SPI.begin();
  digitalWrite(chipSelectPin, HIGH);
  //digitalWrite(rstPin, HIGH);
  Serial.println("Wi-Fi Reset");
  //digitalWrite(rstPin, LOW);
  delay(500);
  delay(6000); //
  Serial.println("Wi-Fi Init");
  Init();
  Serial.println("Wi-Fi Init Complete");
void loop() {
  byte tmp;
  if (Wifi_setup == true)
  //if(1)
        // if there is data from Wi-Fi side.
  tmp = WizFI210_Read_Byte();
  if ((tmp != SPI_IDLE_CHAR) &&  (tmp != SPI_INVALID_CHAR_ALL_ZERO) && (tmp != SPI_INVALID_CHAR_ALL_ONE)){
             Serial.print(char(tmp));
        // if the connection is established, incoming serial data sent to the peer.
        /*if (Serial.available() > 0) {
          WizFI210_Write_Byte(Serial.read());
        WizFI210_Write_Byte('R');
        //Serial.print(cnt);
        //cnt++;
        //Serial.println(" Sent");
        //delay(500);
byte WizFI210_Read_Byte() {
    byte result;
    digitalWrite(chipSelectPin, LOW);
    result = SPI.transfer(0);
    return(result);
unsigned int WizFI210_Read_Buf(byte * buf)
  int idx = 0;
  byte tmp;
  byte chk = 0;
  while(digitalRead(dataReadyPin) == HIGH) {
    if ((tmp != SPI_IDLE_CHAR) &&  (tmp != SPI_INVALID_CHAR_ALL_ZERO) && (tmp != SPI_INVALID_CHAR_ALL_ONE)) {
      if (tmp == SPI_ESC_CHAR) {
        chk = 1;
      }else {
        if (chk == 1) {
          chk = 0;
          tmp = tmp ^ 0x20;
        buf[idx++] = tmp;
  return(idx);
byte SpiByteStuff(byte *thisValue)
 if( (SPI_ESC_CHAR  == *thisValue) ||
   (SPI_XON_CHAR  == *thisValue) ||
   (SPI_XOFF_CHAR == *thisValue) ||
   (SPI_IDLE_CHAR == *thisValue) ||
   (SPI_INVALID_CHAR_ALL_ONE == *thisValue) ||
   (SPI_INVALID_CHAR_ALL_ZERO == *thisValue)||
   (SPI_LINK_READY == *thisValue))
  {   // Byte stuffing is required
     *thisValue = *thisValue ^ 0x20;
     return 0x01;
   else
     return 0x00;
void WizFI210_Write_Byte(byte thisValue)
  if (SpiByteStuff(&thisValue)) {
    // Byte stuffing is required.
    SPI.transfer(SPI_ESC_CHAR);
    SPI.transfer(thisValue);
void WizFI210_Write_Buf(byte *s)
  while (*s != '\0')
    if (SpiByteStuff(s)) {
    SPI.transfer(*s);
    s ++;
    delay(10);
byte Check_OK(byte * buf, unsigned int TimeOut)
  unsigned int idx = 0;
  unsigned int t=0;
  byte tmp;
  char * ret = NULL;
  while(1) {
      buf[idx++] = tmp;
                        //if (idx > sizeof(buf)) idx = 0;
      if (tmp == ']') break;
    if (t++ > TimeOut) {
                  //  Serial.println("Time out");
                    break;
    delay(10);
    // flush
        delay(10);
  ret = strstr((char *)buf, "[OK]");
  if (ret != NULL) {
          return 1;
        } else {
          return 0;
byte IsCommandMode()
    byte msg[]="AT\r\n";
    WizFI210_Write_Buf(msg);
    memset(msg, '\0', sizeof(msg));
    return(Check_OK(msg, 2000));
void Init(void)
   byte Msgbuf[68];
   byte key;
 Serial.println("Send Sync data");
 WizFI210_Write_Byte(SPI_IDLE_CHAR);
 delay(1000);
  while(1) {
  key = WizFI210_Read_Byte();
  if ((key != SPI_IDLE_CHAR) &&  (key != SPI_INVALID_CHAR_ALL_ZERO) && (key != SPI_INVALID_CHAR_ALL_ONE)) {
                // debug
    //Serial.print(char(key));
       if (digitalRead(dataReadyPin) == LOW) break;
        delay(10);
 Serial.println("Ok");
        // Send AT
        Serial.print("\r\nSend AT");
  sprintf((char *)Msgbuf, "AT\r");
  WizFI210_Write_Buf(Msgbuf);
  memset(Msgbuf, '\0', sizeof(Msgbuf));
  if (Check_OK(Msgbuf, 2000))  Serial.print(" : Success");
  else {
                Serial.println("\r\nSend 2nd AT");
    if (Check_OK(Msgbuf, 2000))  Serial.println(" : Success");
    else Serial.println(" : Error");
      if (Setup_WiFi() == true) {
        Wifi_setup = true;
        Serial.println("\r\nConfiguration OK");
      }else {
        Wifi_setup = false;
        Serial.println("\r\nConfiguration fail");
boolean Setup_WiFi(void)
   byte Msgbuf[128];
    Serial.println("\r\nTest Command");
    sprintf((char *)Msgbuf, "AT+WD\r");
    Serial.print((char *)Msgbuf);
    if (Check_OK(Msgbuf, 10000)) Serial.println(" : Success");
  //  AT+WAUTO
  sprintf((char *)Msgbuf, "AT+WAUTO=0,%s\r\n", SSID);
        // Serial.print((char *)Msgbuf);
  if (Check_OK(Msgbuf, 1000)) Serial.println(" : Success");
  //  AT+WAUTH
  sprintf((char *)Msgbuf, "AT+WAUTH=%d\r\n",0);
  //  AT+WWPA
  sprintf((char *)Msgbuf, "AT+WWPA=%s\r\n",WPA_PASS);
#ifdef DHCP_ENABLE
  //  AT+NDHCP
  sprintf((char *)Msgbuf, "AT+NDHCP=%d\r\n",1);
#else
  //  AT+NDHCP
  sprintf((char *)Msgbuf, "AT+NDHCP=%d\r\n",0);
  //  AT+NSET
  sprintf((char *)Msgbuf, "AT+NSET=%d.%d.%d.%d,%d.%d.%d.%d,%d.%d.%d.%d\r\n",
          IP[0],IP[1],IP[2],IP[3],Sub[0],Sub[1],Sub[2],Sub[3],Gw[0],Gw[1],Gw[2],Gw[3]);
#endif
  //  AT+NAUTO
  sprintf((char *)Msgbuf, "AT+NAUTO=%d,%d,,%d\r\n",Server_Mode, Protocol_TCP, ListenPort);
  //  AT+XDUM
  sprintf((char *)Msgbuf, "AT+XDUM=%d\r\n", 0); //  1: Uart message is disable, 0: enable
        // MAC address writing
  sprintf((char *)Msgbuf, "AT+NMAC=00:08:DC:18:76:57\r\n");
  //  ATA
  sprintf((char *)Msgbuf, "ATA\r\n");
        //Serial.print((char *)Msgbuf);
  if (Check_OK(Msgbuf, 20000)) {
          return true;
  else {
          return false;
It configures well and I get configuration OK message but no voltage on antenna.Please tell me how to make the wizfi210 send some random data (Setting it to AP or connecting it to another router is not required but just need voltage on the antenna).
I am now measuring the antenna signal strength using an RF meter and all I see are short bursts of signal coming out of it.To make it more consistent should I set it to 1 Mbps and I am also thinking of using an Arduino Due which runs at 84Mhz. Right now the arduino pro mini I am using works only at 8 mhz and the SPI frequency is at 125 khz.I need to push data a 1mbps. Any suggestions would be helpful.I think I might have to use serial port for sending data on it at say 1 mbps.
