I am successfully able to send messages to WIZ105SR from different PC's in the same gateway using the "Device Terminal" program. However, I am not able to do so using PC's in different gateways.
How can I send messages from remote PC?
I am able to successfully ping from my home PC but cannot ping from a remote PC. The IP address that I have set for WIZ105SR is not visible from outside. I need to be able to get to my router and then to WIZ105SR. I just dont know how to go about doing this?
Both devices must have a public IP address.
Please check the IP address of both devices(WIZ105SR and Remote PC).
If you mean the router is residential gateway, maybe your router has a public IP address.
And your router gives private IP address to WIZ105SR.
In this case, set the port forwarding option of your router.
