I follow the instructions of the youtube video to enter boot mode but with NO success. As the module is powered on I plug the connector to jumper 3 , press the reset button but only the LED 4 lights up and not LED 3 as well. Any ideas?
Also when I open putty I open a session with the 115200, 8, 1, N settings then at the screen I suppose to write it does not accept any letters! I type and nothing shows on screen!
Any ideas on that?
which terminal server software they use in the youtube video?
Also I opened the firmware update tool and cannot find the wizfi250. Do I need to install additional drivers?
I put the jumper for boot mode, and only the wifi LED is ON , is this correct?
In device manager I get “unknown device” - FT232R USB UART and no association with a COM port, so I cannot communicate through putty.
ARE there any drivers for the wizfi?
3.I have managed to send data to wizfi from MCU
when I send “AT” I get a response “++AT”
when I send “AT\r” I get a response “error invalid input”
when I send anything else I do not get a response, even if I send “AT+UART=?” ANY IDEAS?
latest update
when I send AT commands and listen for a response I get null value -like nothing.
So if I send to wizfi “AT\r” and get an invalid response, THEN what is a valid command?
What video do you mean? I set the boot mode but maybe the driver is the problem. *edit installed the driver and managed to upgrade wizfi module!
I downloaded the driver but has extension of .zzz HOW do I use that? ( edit FIXED is OK now I changed the extension to ZIP - extracted it and worked THANKS!!! )
When I send the AT commands only the wifi LED is on the MODE is off, is this correct?
Also I try to send AT commands from the MCU with both LEDs off MODE & WIFI and I get no response!!!
On which FORMAT should I send the AT commands?
So far I send as string ( “AT” )
should I send ( "A,T\r) ?
should I send as ascii number? ( 65 , 84 ) ? 65 for A and 84 for T ? What about the comma?
First, I already explaned about operation of LED.
AT command operates in “command mode”.
It doesn’t matter “AT” or “AT\n”. Both of them was handled by WizFi250.
I do not know which MCU to use, but it might be a good idea to analyze the WizFi250 source in the Arduino Library.
If you need it, you can get to follwing. github.com/Wiznet/WizFi250_arduino_library
