Does anybody has a good TCP client example working? I’ve been using the Berkeley Socket API found in
./ioLibrary/Ethernet/socket.c but sometimes it behaves strangely. I have to insert some delay between functions. Sometimes works fine but not others. I’ve been analyzing the return value but does not help.
Example:
I have to insert some delays between creating the socket, open the connection and send or receive data:
sn=0 // using only the socket 0
socket(sn, Sn_MR_TCP, port_server, 0);
delay(100);
connect(sn, destip, destport)
delay(100);
send(sn, buf+sentsize, size-sentsize);
I also realized that depending the server location i have to change the delay time. The further away the server (ex. on Amazon) the higher are the changes to get errors. If i test in a local machine it works most of time.
Any ideia?
Best regards,
Hello, joaopaulob
Are you using W7500 with TCP client?
You only can send data in TCP after tcp connection success.
That is why it is hard to guess the network timing, with delay.
So, w7500 supports useful register, Sn_SR(sn), which can check network conditions.
With Sn_SR(n),
while(!getPHYCFGR()); // phy link check
while(Sn_SR(sn) != SOCK_ESTABLISHED); // check the tcp connect success
while(Sn_RX_RSR(sn) != 0); // if server send some data
recv(sn,recv_buf,recv_length);
You can find the Sn_SR & Sn_RX_RSR in W7500 reference sheet.
http://wizwiki.net/wiki/lib/exe/fetch.php?media=products:w7500:w7500_rm_v109.pdf
Thank you
lawrence
I found the problem. The socket.c was set as non_blocking mode. The “Sn_SR(sn) != SOCK_ESTABLISHED” was not checked.
Thanks
You did !!
I am glad to hear that!
Thank you for your interests.
Feel free to ask anytime.
Thank you
lawrence
