RJ45 connectors - compatible footprint - preferred parts - second source
I have compiled a list of THT integrated magnetics pin compatible preferred parts I wish to share. Symmetrical transformer with caps & 75 Ohms.
If you have any more to add – or remove from the list, please post here:
This is a good site for alternate parts. Most found through this site:
J1B1211CCD
https://octopart.com/search?q=J1B1211CCD
http://www.shopwiznet.com/lanotattachments/download/file/id/144/store/1/
MC001515
http://uk.farnell.com/multicomp/mc001515/connector-rj45-jack-r-a-8p8c-tht/dp/2691252
http://www.farnell.com/datasheets/2189833.pdf?_ga=2.30180346.414526026.1495116342-2131139551.1485446220 .
J00-0065NL
https://octopart.com/search?q=J00-0065NL
http://productfinder.pulseeng.com/product/J00-0065NL
http://productfinder.pulseeng.com/products/datasheets/J403.pdf
http://productfinder.pulseeng.com/files/datasheets/J414.pdf
J0011D21BNL
http://productfinder.pulseeng.com/product/J0011D21BNL
https://octopart.com/search?q=J0011D21BNL
LPJ4011ABNL
http://www.link-pp.com/upload/file/20160427/20160427151320242024.pdf
RB1-125BAG1A (UPDATE: DIFFERENT PIN OUT: Common center taps)
https://www.shopwiznet.com/index.php/lanotattachments/download/file/id/95/store/1/
XRJG-01S-4-D22-210
http://www.xmultiple.com/ModPics/1x1%20Tab%20Down/XRJG-01S-4-D22-210(01).pdf
XMG-J1B121ZCCD
http://www.xmultiple.com/ModPics/XMG/XMG-J1B121ZCCD.pdf
LPJ0012AHNL
http://www.link-pp.com/upload/file/20170223/20170223145669116911.pdf
LPJ0013AHNL
http://www.link-pp.com/m/?product/201604195253.html
http://www.link-pp.com/upload/file/20160419/20160419161061916191.pdf
BS-RB10005
https://octopart.com/search?q=RB10005
http://www.i-vis.co.jp/pdf/wiznet/tcpip_chip/magjack/BS-RB10005(005-00).pdf
Hello, jnewcomb
Thank you for your information.
It is so useful!
If there are more, I will add
Hi jnewcomb.:slight_smile:
I am H/W engineer in WIZnet.
Thank you for your good information. :heart_eyes:
I will review this.
You will help a lot of people.
Scott.
I can’t work out how to edit my first post, so I’ll append info here…
So, I have a working design… see link below.
J0011D21BNL → Double check the footprint of the device… I think its different…
Price…
I have chosen the J0011D21BNL from PULSE - because we already use it on another product.
Its a good brand and can be purchased from reliable sources for around 1.10 USD. (Check the footprint of the connector)
So, if you have a low cost easy to find device, please share here…
Thanks…
I know the topic is old, but would this RJ45 jack fit, I am planning to make a POE application:
Link-PP LPJ4320GENL
You can see the circuit in the datasheet
I compared with the reference design here and I think it’s correct.
LPJ4320GENL
Thank you in advance!
Patrick
Hi mcpat,
The LPJ4320GENL Looks good.
Note: The connector I used does not have the 4 x 1nF parts integrated into the connector (as shown in your screenshot)
PULSEJACK part - Clarification…
J0011D21BNL can’t be used with the reference schematic (and my supplied schematic) as Pins 2-4 are shuffled. If you use it, you must change your schematic accordingly.
@jnewcomb Thank you very much! So I give it a try. It will take some time because it’s my hobby, but after testing I will come back and will give a feedback.
