cannot configure wiz1000
#1
I am using a Wiz1000 on a dhcp server. When I use the classic configuration tools, I cannot see my wiz1000. At boot i see a UART message (through a terminal software):
"> Listen : OK
: 255.255.255.0
G/W IP ADDRESS : 192.168.11.1
WIZ1000 Ver. 01.06
MAC ADDRESS : 00.08.DC.51.80.FA
LOCAL IP ADDRESS : 192.168.11.2
SUBNET MASK : 255.255.255.0
G/W IP ADDRESS : 192.168.11.1"
however, the default gateway I am using in my dhcp server is not the same. How can I configure manually the default gateway of the wiz1000 ?
Thank you in advance,
Kind regards,
Thibault CAPELLE
#2
I think your WIZ1000 is in an initial state.
If you want to use WIZ1000 on DHCP server, you need to change the WIZ1000 setting from Static (default) to DHCP.
The reason for not searching in ConfigTool is that WIZ1000 has network information that is not assigned by DHCP server.
First, connect the PC and WIZ1000 directly with LAN cable (1: 1) and search with ConfigTool.
Next, change the WIZ1000 setting to DHCP.
Or assign a specific IP address to your WIZ1000’s MAC address from your DHCP server, and modify the WIZ1000’s network information accordingly.
