Please tell me is it possible to somehow avoid terminating 0D and 0A after message:
{1,192.168.16.6,51310,6}ABCDEF{0D}{0A}
Reported length is 6, and real length is 8.
I tried with AT+SFORM=111111100,… , but I got even worse situation:
{1,192.168.16.6,51472,6}ABCDEF{1,192.168.16.6,51472,6}
Can message be finished with nothing more, beyond the reported length in header ???
Regards
Hi, djdjdjole
As you know,the last two words(0d0a) means crlf(new line).
Therefore, when you tried ‘AT+SFORM=111111100’, there was no crlf.
Would you check what i understand is correct, do you want to do crlf without 0d0a?
Regards,
Maybe I was not so clear. Default way of coding data (when module is in TSN mode) is to send header info like this: {1,192.168.16.6,51310,6}, before sending the message “ABCDEF”. But in reality there is 0D0A attached afther the message - which means: {1,192.168.16.6,51310,6}ABCDEF{0D}{0A}. I don’t know what is the meaning of adding 0D0A at the end and also, why it is not reported as overall message length.
What I tried was to find the way to move it away from the message tail and considered AT+SFORM as good point to achieve so. However, I didn’t succseed, I achieved to move 0D or 0A from the tail, but not the BOTH of them. When I try moving both of them - AT+SFORM=111111100,… and look at the message coded by WiFi module- it was: {1,192.168.16.6,51472,6}ABCDEF{1,192.168.16.6,51472,6}.
No matter, I unwillingly re-coded my source to that situation (0D0A at the tail), but don’t know why it is there, when segment length is already given inside paranthesis. I am forced to do communication in command mode (again unwillingly), because of problems regarding transparent mode that I point to you at our previous mails.
Regards
As I said before, ODOA means crlf(New line).
So, when you tried ‘AT+SFORM=111111100,…’, the results make sense.
(Because you set ‘00’ at last two bits(0D0A) , there was no crlf.)
From what I know, there is no way to do crlf(new line) without ODOA.
Thanks,
