Hi…
I configured it and tested in TCP Client / TCP server / UDP mode using Hercules.
Now I have it in the Mixed mode.
1.) Serial parameters are 115200 E71 - conn to PLC.
Client mode:
I connect to w1000 ip address:5000 and I can send data to PLC and it received it.PLC surely answers but I don’t see this data in client window.
Server mode:
I started server on laptop port 5001. This is entered also to config tool. I can send data to device, but I don’t see the reply.
2.) Same serial parameters - serial terminal instead of PLC:
If I connect RS232 terminal instead of PLC, same baud rate, then I see the data I sent from ethernet TCP client via w1000 to RS232.
Also if I type answer to RS232 terminal, now I see those data on my TCP client window!
Why don’t I see them when PLC anwers? Timing??? PLC answers very quick!
For server mode:
Using serial terminal instead of device I see that in server mode RS232 device must establish connection via w1000 to the external TCP server first. After connection is made, then I can send data. Problem is that my PLC doesn’t send nothing first!
For client mode:
I should see the data, because I established contact from PC client first.
Can You help? Firmware 1.6. Any new firmware?
192.168.1.198 iz w1000
192.168.1.23 is my laptop with Hercules
