I have a WIZwiki-W7500 with an micro SD slot. I have tried to run the diagnostics program W7500x_WZTOE_MANU.bin and I get the following result
on the serial port connected to the USB port:
rC3ßÅéÍq`å)
val: 12C0, getTIC100US: 12C0, (12C0)
…PHY is linked.
[DEBUG] SD Card Test
[DEBUG] init ret : 1 , SD Card Type : 0
SD Test Fail!![DEBUG] CID / MID : 0x00
[DEBUG] CID / OID :
I do not think this is the normal result but I do not find any information how to get the SD-slot working.
thanks for your information, now it works after uploading the latest CMSIS-DAP firmware.
To make the instructions for uploading a bit clearer please add what to do after point 4 Drag and Drop or copy the updated firmware to the CRP_DISABLD disk for CMSIS-DAP.
I was unsure what to do next so I remowed the power to the board and put it back again and this seems to work but what is the recommended procedure?
I found a zipfile on the mbed page for the W7500x_WZTOE_MANU.bin I think.
You can find “SDFileSystem_HelloWorld_WIZwiki-W7500” project in http://cybermakerspace.com/Curation/Library.html
Please select that project.
Select “Import into Compiler”.
If you need, login.
Compile the project.
Use SDFileSystem_HelloWorld_WIZwiki-W7500_WIZWIKI_W7500.bin file.
