I use WizIsp to program W7100A and mistakenly tried to program ~64KB of code into 255B data memory. Loading stopped at 17% of progress. Now WizISP can’t establish a connection with W7100A.
I broke a bootloader code? Can I run the chip again?
Sorry, I didn’t mention that W7100A is mounted on the WIZ107SR module, i use it to implement own application.
Now I am working with another WIZ107SR module and its successful programming as before. But a broken module at the same time does not respond to attempts to establish a connection via COM port.
