Just download the latest io_lib and there are compile errors in socket.c. I’m using W5500 and WIZCHIP is defined as 5500;
error: ‘Sn_MR_IPRAW’ undeclared (first use in this function)
case Sn_MR_IPRAW:
error: ‘SOCK_IPRAW’ undeclared (first use in this function)
if(tmp != SOCK_MACRAW && tmp != SOCK_UDP && tmp != SOCK_IPRAW) return SOCKERR_SOCKSTATUS;
Jim
2
Dear Lee_Trueman
I found errors.
Please change your code to the following.
w5500.h
#define Sn_MR_IPRAW 0x03 /**< IP LAYER RAW SOCK */
#define SOCK_IPRAW 0x32 /**< IP raw mode socket */
ioLibrary will be update later.
Thanks Jim
On a porting note, i’m looking to use this with RTOS Chibios/RT, What would you suggest example wise as a guide ?
Or if you have a porting guiding even better
Jim
4
Sorry, there is no example or porting guide for Chibios/RT.
I found RTOS examples in wizwiki and wiznetmuseum.
http://wizwiki.net/wiki/doku.php?id=dev:coos&s[]=rtos
http://wiznetmuseum.com/?s=RTOS
