The WIZ120SR is the perfect part for a project my customer wants. This will save me a lot of time as it is plug and play. I am in the process of laying out a PCB for the WIZ120SR Module but can not find a matching socket for the 1x14 2mm pitch header used on the module. Does anybody have a Digikey or Mouser part number that will work I would like to be able to unplug (remove) the Wiz120SR from the main board. Thanks for any help.
It is a common pin header.
If the corresponding pin header has the same pitch, it is usable.
Can not find the product in Mouser and Digikey?
Kei,
Thanks for the response, but, nope - unable to find any 1 X ZZ 2MM Headers. I found a supplier on eBay that has 1x50 2MM headers I can cut down to 14 pins and ordered them from China. I think problem solved.
