Wizfi 250 TCP server
Hi Team,
I am working on TCP webserver on mbed. The Wizfi 250 module connects to AP and obtains the IP address, then I SCON command for TSN socket and then MEVTMSG command which give error.
After this When I try to check loading the IP address on my mobile, it doesnt display the HTTP response that I am sending from the application. I checked the console, but dont see any response.
Following are the output on console,
Command = AT
[OK]
Command = AT+MECHO=0
[OK]
Command = AT
[OK]
Command = AT+WNET=1
[OK]
Command = AT+WSET=0,testAP
[OK]
Command = AT+WSEC=0,password
[OK]
Command = AT+WJOIN
Joining : testAP
Successfully joined : testAP
[Link-Up Event]
IP Addr : 192.168.43.94
Gateway : 192.168.43.1
[OK]
Command = AT+WSTATUS
IF/SSID/IP-Addr/Gateway/MAC/TxPower(dBm)/RSSI(-dBm)
STA/testAP/192.168.43.94/192.168.43.1/00:08:DC:51:3D:B6/31/55
[OK]
WIFI connected to hotspot
The target IP address is ‘192.168.43.94’
Command = AT+SCON=O,TSN,80,0
[OK]
Command = AT+SMGMT=?
Number of Sockets : 1 (SCID/Mode/Remote/Local/DataMode)
0/TSN/0.0.0.0:0/80/0
[OK]
Command = AT+MEVTMSG=1
[ERROR: INVALID INPUT]
Error in AT+MEVTMSG response
Wait for connection…
Accept…
Thanks,
Satish.
hi, satish040
i am apologize for late answer.
I think your WizFi250 firmware does not support the command.
So, I recommand you to use latest firmware !:slight_smile:
it is available below
http://wizwiki.net/wiki/doku.php?id=products:wizfi250:wizfi250firmware:start
Thanks,
