Command to reset WIZ550S2E?
Is there a command to reset or factory reset the WIZ550S2E module via UART? I know it can be done using the Configuration Tool, but I want to know if it is possible over UART.
Thank you!
Hi
WIZ550S2E no has factory reset command. but, It has RESET command.It is AT+MRST command.
Thank you
