multi socket TCP IP
I’m using WIZ550SR module for my project. I have a question for you:
  • When I config this module run client mode can I create two (or more ) socket to connect to server via two (or more) port at the same time? See the picture below
I contacted Mr Kit Wan (kitwan@wiznet.hk), he said: customized firmware WizSE module W5500S2E-S1 which can below connect up to 4 TCP connections.
I already have WIZ550S2E modules (http://wizwiki.net/wiki/doku.php?id=products:wiz550s2e:wiz550s2eds_en), Can you send for me the customized firmware version of W550S2E which support multi socket handing function?
I will use one of two module: W5500S2E-S1 or WIZ550SR for my project.
Can you help me to choose a S2E module which support connect 2 server socket is the best.
Thank you so much!
Phuc Truong
Sorry for the late reply.
Did you solve the problem?
