WIZ750SR 디버그 포트에 콘솔을 연결하고 놔두면 아래와 같이 주기적으로 reboot하는것 같은 메시지가 표시됩니다.
아무런 조작도 하지 않았습니다.
원래 이렇게 동작하는건가요?
WIZ750SR
>> WIZnet Serial to Ethernet Device
>> Firmware version: 1.1.0 Stable
- Device name: WIZ750SR
- Device mode: TCP_SERVER_MODE
- Network settings:
- Obtaining IP settings: [Static]
- TCP/UDP ports
+ S2E data port: [5000]
+ TCP/UDP setting port: [50001]
+ Firmware update port: [50002]
- Search ID code:
- Disabled: [None]
- Ethernet connection password:
- Disabled (TCP server / mixed mode only)
- Connection timer settings:
- Inactivity timer: Disabled
- Reconnect interval: [3000] (msec)
- Serial settings:
- Data UART port: [UART0]
+ UART IF: [RS-232/TTL]
+ 115200-8-N-1 / Flow control: NONE
- Debug UART port: [UART2]
+ 115200-8-N-1 / NONE (fixed)
- Serial data packing options:
- Time: Disabled
- Size: Disabled
- Char: Disabled
- Serial command mode swtich code:
- Enabled
- [2B][2B][2B] (Hex only)
- Hardware information: Status pins
- Status 1: [PA_10] - PHY link
- Status 2: [PA_01] - TCP connection
- Hardware information: User I/O pins
- UserIO A: [PC_13] - Analog / Input
- UserIO B: [PC_12] - Digital / Input
- UserIO C: [PC_09] - Digital / Output
- UserIO D: [PC_08] - Digital / Output
MAC: 00:08:DC:53:AF:D2
IP : 192.168.11.2 / Port: 5000
GW : 192.168.11.1
SN : 255.255.255.0
DNS: 8.8.8.8
> SEG:TCP_SERVER_MODE:SOCKOPEN
