I would like to achieve 150Mbps receive PHY rate and 150Mbps transmit PHY rate using 40MHz bandwidth.
What is an appropriate method?
Hi, Mateusz_Baczewski
–> I am getting confused. Could you explain in detail? (background like what you want to do with WizFi310) .
Hi, I try to explain. I use my WizFi 310 in AP mode. My configuration set 20MHz bandwidth and I suppose I use only 72.2Mbps rate. I learn about the possibility to speed up my Wi-Fi transfer thanks to extend bandtwidth to 40MHz (from WizFi 310 datasheet). I don’t know AT command to switch to 40MHz.
Hi ! Mateusz_Baczewski.
I am sorry to say WizFi310 doesn’t support that function
Have a nice day !!
Thanks,
Thank you for letting us know that.
Also, I am sorry to have confused you.
We’ll fix that.
Thanks,
