Data Receiving From Which IP?
Is it possible to see IP address of the Client connected to Ethernet from which am getting data. Am connected My WIZ107SR to a Switch and that switch connected to two clients.
But in serial application, am able to see the pay load only but I need the IP address from which am getting data.
Hi @Muralidhar,
WIZ107SR does not support the features you mentioned.
However, our new WIZ750SR module is hardware and software compatible with WIZ107SR and supports 1: N communication in UDP mode. This mode is working possible only after your module receives data first.
(note that, the module will send the data (from the serial interface) to the destination that sent the data.)
Please refer to below link.
https://wizwiki.net/wiki/doku.php?id=products:wiz750sr:usermanual:start#udp_mode
