I’ve been working with wiz830MJ module for several days, I’ve managed to run TCP Server mode successfully (module received data from PC Client and sent data to it). After several days of using module can’t establish a connection! Socket is initialized, but ping command isn’t carried out, PC client can’t connect. Socket closes very often (at listen stage or at establishment stage: Sn_SSR=0x00).
It seems there was no contact in my self-made cable… )
Sometimes small thing make problem.
Anyway it’s good to hear that you find the cause of the problem.
But I’ve faced another problem: module doesn’t work every time when I start host processor programme (I use Altera’s Nios2). Sometimes it works, sometimes it doesn’t. Simple modification of the programme (for example, adding of 1 printf(regN_value) operator - for debugging purpose) could lead to fail. Then I can make 1 more modification and module works OK. Sometimes module gets to “socket listen” mode, but ping command doesn’t work and printf(IP_reg) shows 0!!! It seems that in that case IP address isn’t written correctly. In another situation module doesn’t go into SOCKET_LISTEN mode. But sometimes everything works right: I achieved data speed more than 20 Mbits/s in each direction. I’ve checked address bus, data bus, СS, WR, RD, but haven’t seen any problem with them.
Do you have working module and have a problem with specific module?
When wiz830mj’s IP information as Source, Gateway, SN and MAC address is correct writting, wiz830mj can be ping-reply. Becase Ping-request isn’t working, wiz830 register access is likely to be wrong or link status is unstable.
Wrong wiz830 register access is related to timing and register map to your system.
Can you show me your wiz830mj access timing diagram? I will check it.
thank you.
I’ve got two modules, both of them work the way I posted above. I guess, at least one problem could be with writing process (from time to time IP register doesn’t contain right IP address). In my system data appear on the tristate bus before wr and cs signals go low (Altera’s tristate controller works this way). Is it correct or not? Does datasheet mean that data must be on the bus no earlier than tDATAs?
As regard to write timing, WR and CS goes low at the same moment, WR stays low for 70 ns, CS stays low for 90 ns. WDF[2…0]=0, so data sample is taken 7 ns later from the moment when wr/cs are deasserted. Also I’ve tried WDF=3 but didn’t see any difference.
Can you check the timing with oscilloscope?
If yes, it’ll be helpful for us to resolve the problem.
Yes, I’ve checked timings, they look OK.
Please send the timing to us then we’ll check it.
We are having Christmas holidays till 9th of January, so I’m not at work now. I’ll send timings later. How to do it? Is there a tool for that on this site?
You can attached the picture of timing.
There is “upload attachment” tab under the edit area.
I attached a .jpg file with read/write diagram. D7,D6-addr1,addr0, D4,D3-data1,data0, D2-RD, D1-WR, D0-CS. I use following code to get this diagram:
IOWR(W5300,0x001c,0x0001);
while(1)
{IOWR(W5300,0x0201,0xff02);
IORD(W5300,0x001c);}
IOWR: 2nd parameter -address, 3rd parameter - data;
IORD: 2nd parameter - address.
The problem is still actual)
I was checked the time but it is correct. But for more safe, /CS signal include the /RD siganl as WRITE timing.
For example,
CS : ---------______|/-------------
RD: -------------_/–|--------------
Anyway, I wonder your code for what.
*(uint16_t)* 0x001C = 0x0001; // RTR = 0x0001
while(1)
*(uint16_t*) 0x0201 = 0xFF02; // Sn_MR = 0xFF02
var = *(uint16_t*) 0x001C; // READ RTR
First, You should verify to access the W5300.
For checking read time, Verify IDR regsiter. If failed, you should be control read siganl timing.
while(1) // Infinite loop until IDR == 0x5300
if( IORD(W5300, 0x00FE) == 0x5300 ) break;
For checking read/write time, Write GAR regsiter and Read it and compare two.
[code]
IOWR(W5300,0x010, 0xAABB) ; // GAR0 = 0xAA(0xBB) GAR1=0xBB(0xAA), It depends on system-endian as big or little.
IOWR(W5300,0x012, 0xCCDD); // GAR2 = 0xCC(0xDD) GAR3=0xDD(0xCC)
uint16_t gar0 = IORD(W5300,0x0100);
uint16_t gar2 = IORD(W5300,0x0102);
if( gar0 == 0xAABB && gar2 == 0xCCDD)
printf(“gar0=%04X, gar2=%04X\n”, gar0, gar2);
Good luck to test it.
Code I posted above was used just to get write/read diagram, it’s not a part of a programme.
I checked write/read operations (IDR, GAR), there wasn’t problem with them. It seems that issue is related to processor (sometimes adding of 1 printf operator leads to fail - no ping). I also worked with wiz820io (the system was the same - Wiz module+ FPGA based Nios 2 host processor), but didn’t have such an issue. If I manage to find the reason I’ll post an explanation here.
I’m so sorry about mis-understanding your problem.
It seems to be difficult to find the reason of problem.
I suggeust to check memory viloation or stack overflow by just adding a printf.
And, the stability without printf() be checked how long is running.
I’m sorry, i don’t help you.
I hope that you can solve the problem as soon as possible.
I will wait to your good post and good luck to you.
