Hi Good Days,
I have a lot of WIZ110SR, and I use them in Tcp / ip to Serial mode without any problems.
but I am having a problem under “Use Udp Mode”.
I want to make the UDP server port random. local port is 161 all time.
So if I get data from the any port to the PC den WIZ110SR, I want to send the data to that port.
wiznet local port = 161.
server port is 60542 ==> wiznet 161. port / wiznet 161.port ==> 60542
same time.
server port is 1528 ==> wiznet 161. port / wiznet 161.port ==> 1528
Also, Wiznet 110sr send udp packet only 1 byte , ı send on serial 10 byte packet but only udp send 1 byte to 1 byte, so wireshark mal formed packet read.
