I’m trying to open soket 0 in the MACRAW protocol, but when I check S0_SSR, it becomes 0x0100. This happens even if I try to open a socket in another protocol.
In this case, ping is valid, reading other registers is working correctly!
However if your application is not startup timing critical, increase this delay to 2 ms as per datasheet.
These settings are not required in for MACRAW mode because they make no sense. They make sense if you use other sockets for IPRAW/TCP/UDP communication.
This algorithm actually is not correct, even if it present in the datasheets for all W5x00 products. The right one is:
I removed temp1 from the code, you may still keep it for debugging purposes. You also must implement some timeout scheme so that code does not stuck in case of something goes wrong.
In MACRAW mode chip will receive only packets dedicated for its configured MAC address, and (I guess) MAC broadcast packets (with destination MAC address of FF:FF:FF:FF:FF:FF).
You can see what is going on the network using Wireshark (e.g. installing it on bridge computer), and only then state that W5300 does not get any packets and there’s an issue with W5300 or its configuration. When you ping W5300, I think these ICMP packets are intercepted before socket stack and they will not appear in any socket RX buffer.
It may also happen that you address wrong register to receive RX data size. Not possible to know because you do not detail code MACRAW_session(); you have issue in.
Are you sure your code is not stuck here - that sysinit does not return with 0?
void Resive_UDP_pocket (void)
I do not see code of this routine doing things required in datasheet:
Received DATA?
First method :
if (Sn_IR(RECV) == ‘1’) Sn_IR(RECV) = ‘1’; goto Receiving Process stage;
/* In this case, if the interrupt of SOCKETn is activated, interrupt occurs. Refer to IR, IMR
Sn_IMR and Sn_IR. */
Second Method :
if (Sn_RX_RSR != 0x00000000) goto Receiving Process stage;
Allocating 8 kilobytes of memory for each socket. I did this only for the sake of verification, since I understand that after reset the memory will be distributed in a similar way!
This function is performed correctly! (1)
The program does not reach the function Resive_UDP_pocket() and so I did not understand it yet, because I see that there is no response about setting the desired mode in the register S0_SSR!
