Thank you for your reply.
Sorry, didn’t think it mattered. I tried different values, now it’s: aa:bb:cc:dd:ee:ff.
Yes, exactly two bytes that i’ve sent.
When I connect directly I only get responses to ping requests from pc, there are no any other packages coming from w5100 device (except for those couple of lucky packages).
I drive w5100 with FPGA - Kintex-7 of Xilinx (maybe unconventional way to affect chip, but it wasn’t up to me to choose). Anyway, my code is on VHDL (excuse me, not good at this, I’m more cpp guy)
Summary
– functions of wr/rd to registers work fine
VARIABLE source_port : std_logic_vector(15 downto 0) := x"07D0";
begin–p1 process
if (reset = ‘1’) then
nWR <= Inactive;
nRD <= Inactive;
nCS <= Inactive;
done <= ‘0’;
read_data <= x"00";
cnt := 0;
step_of_progr <= 1;
memcpy_fl := false;
step_of_memcpy <= 0;
mem_addrA_sign <= x"0000";
mem_data_inA_sign <= x"00";
NUM_OF_TRIES := 0;
elsif (rising_edge(clk)) then
if (step_of_progr = 1) then
cnt := cnt+1;
Soft_Reset(cnt);
elsif (step_of_progr = 2) then
cnt := cnt+1;
ProcReadReg(cnt, MR); -- check if reset bit is gone, and it is
elsif (step_of_progr = 3) then
cnt := cnt + 1;
IND_AINC_data_MR := x"03";
Write_MR(cnt, IND_AINC_data_MR);--set AutoIncrement bit and Indirect addressing(0x03)
----------------------------Actual INIT STEP : GATEWAY, IP, MASK--------------------
elsif (step_of_progr = (start_1_stage+2)) then
cnt := cnt + 1;
temp_16 := x"0001";
SetAdr_AINC(cnt, temp_16);--set start address to write to
------------------GATEWAYs()-------------
elsif (step_of_progr = (start_1_stage+3)) then
cnt := cnt + 1;
GATEWAY_DATA(0) := x"C0";--adr 0001
SimpleWriteReg(cnt, GATEWAY_DATA(0));
elsif (step_of_progr = (start_1_stage+4)) then
cnt := cnt + 1;
GATEWAY_DATA(1) := x"A8";--adr 0002
SimpleWriteReg(cnt, GATEWAY_DATA(1));
elsif (step_of_progr = (start_1_stage+5)) then
cnt := cnt + 1;
GATEWAY_DATA(2) := x"0B";--adr 0003
SimpleWriteReg(cnt, GATEWAY_DATA(2));
elsif (step_of_progr = (start_1_stage+6)) then
cnt := cnt + 1;
GATEWAY_DATA(3) := x"03";--adr 0004
SimpleWriteReg(cnt, GATEWAY_DATA(3));
------------------SUBNET masks-------------------
elsif (step_of_progr = (start_1_stage+7)) then
cnt := cnt + 1;
SUBNET_MASK_DATA(0) := x"FF";--adr 0005
SimpleWriteReg(cnt, SUBNET_MASK_DATA(0));
elsif (step_of_progr = (start_1_stage+8)) then
cnt := cnt + 1;
SUBNET_MASK_DATA(1) := x"FF";--adr 0006
SimpleWriteReg(cnt, SUBNET_MASK_DATA(1));
elsif (step_of_progr = (start_1_stage+9)) then
cnt := cnt + 1;
SUBNET_MASK_DATA(2) := x"FF";--adr 0007
SimpleWriteReg(cnt, SUBNET_MASK_DATA(2));
elsif (step_of_progr = (start_1_stage+10)) then
cnt := cnt + 1;
SUBNET_MASK_DATA(3) := x"00";--adr 0008
SimpleWriteReg(cnt, SUBNET_MASK_DATA(3));
------------------MAC адрес-------------------
elsif (step_of_progr = (start_1_stage+11)) then
cnt := cnt + 1;
MAC_ADR_DATA(0) := x"aa";--adr 0009
SimpleWriteReg(cnt, MAC_ADR_DATA(0));
elsif (step_of_progr = (start_1_stage+12)) then
cnt := cnt + 1;
MAC_ADR_DATA(1) := x"bb";--adr 000A
SimpleWriteReg(cnt, MAC_ADR_DATA(1));
elsif (step_of_progr = (start_1_stage+13)) then
cnt := cnt + 1;
MAC_ADR_DATA(2) := x"cc";--adr 000B
SimpleWriteReg(cnt, MAC_ADR_DATA(2));
elsif (step_of_progr = (start_1_stage+14)) then
cnt := cnt + 1;
MAC_ADR_DATA(3) := x"dd";--adr 000C
SimpleWriteReg(cnt, MAC_ADR_DATA(3));
elsif (step_of_progr = (start_1_stage+15)) then
cnt := cnt + 1;
MAC_ADR_DATA(4) := x"ee";--adr 000D
SimpleWriteReg(cnt, MAC_ADR_DATA(4));
elsif (step_of_progr = (start_1_stage+16)) then
cnt := cnt + 1;
MAC_ADR_DATA(5) := x"ff";--adr 000E
SimpleWriteReg(cnt, MAC_ADR_DATA(5));
------------------W5100 IP address---192.168.11.4-----------
elsif (step_of_progr = (start_1_stage+17)) then
cnt := cnt + 1;
temp_8 := x"C0";--adr 000F
SimpleWriteReg(cnt, temp_8);
elsif (step_of_progr = (start_1_stage+18)) then
cnt := cnt + 1;
temp_8 := x"A8";--adr 0010
elsif (step_of_progr = (start_1_stage+19)) then
cnt := cnt + 1;
temp_8 := x"0B";--adr 0011
elsif (step_of_progr = (start_1_stage+20)) then
cnt := cnt + 1;
temp_8 := x"04";--0012
-------------------INIT : Sn_MR = 0x02------------------------------
elsif (step_of_progr = (start_1_stage+21)) then -- 0x17
cnt := cnt + 1;
S0_MR := x"0400";
SetAdr_AINC(cnt, S0_MR);--установили начальный адрес
elsif (step_of_progr = (start_1_stage+22)) then
cnt := cnt + 1;
SimpleWriteReg(cnt, data_to_S0_MR);
---------------------INIT: S0_PORT = source_port (2+2 bytes)-------------------
elsif (step_of_progr = (start_1_stage+23)) then
cnt := cnt + 1;
S0_PORT(0) := x"0404";
SetAdr_AINC(cnt, S0_PORT(0));--set address to write
elsif (step_of_progr = (start_1_stage+24)) then
cnt := cnt+1;
SimpleWriteReg(cnt, source_port(15 downto 8));--0404
elsif (step_of_progr = (start_1_stage+25)) then
cnt := cnt+1;
SimpleWriteReg(cnt, source_port(7 downto 0));--0405
---------------------INIT: S0_CR = OPEN----------------------------
elsif (step_of_progr = (start_1_stage+26)) then
cnt := cnt + 1;
SetAdr_AINC(cnt, S0_CR);--set address to write
elsif (step_of_progr = (start_1_stage+27)) then
cnt := cnt+1;
OPENn := x"01";
SimpleWriteReg(cnt, OPENn);
elsif (step_of_progr = (start_1_stage + 28)) then
cnt := cnt + 1;
SetAdr_AINC(cnt, S0_CR);--set address to read
elsif (step_of_progr = (start_1_stage + 29)) then
cnt := cnt + 1;
SimpleReadReg(cnt);
----------------------INIT : READ S0_SR----------------------------
elsif (step_of_progr = (start_1_stage+30)) then
cnt := cnt + 1;
SetAdr_AINC(cnt, S0_SR);--set address to read
elsif (step_of_progr = (start_1_stage+31)) then
cnt := cnt+1;
SimpleReadReg(cnt);
elsif (step_of_progr = (start_1_stage+32)) then
if (temp_read_data_08 /= SOCK_UDP) then
step_of_progr <= step_of_progr + 1; -- finish init and retry
else
Done <= '1'; -- initialization is done successfully
step_of_progr <= (start_4_stage); -- GOTO Sending stage
end if;
----------unsuccessfull INIT : S0_CR = CLOSE-----------------------------------
elsif (step_of_progr = (start_1_stage+33)) then
cnt := cnt + 1;
Write_MR(cnt, IND_AINC_data_MR);--установка косв адресации и бита автоинкремента (0x03)
elsif (step_of_progr = (start_1_stage+34)) then
cnt := cnt + 1;
elsif (step_of_progr = (start_1_stage+35)) then
cnt := cnt + 1;
CLOSEe := x"10";
SimpleWriteReg(cnt, CLOSEe);
elsif (step_of_progr = (start_1_stage+36)) then
step_of_progr <= (start_1_stage + 21); -- retry to init
–=============SENDING PROCESS → 4 stage==========================-------
– check FRee memory size
elsif (step_of_progr = start_4_stage) then
cnt := cnt + 1;
SetAdr_AINC(cnt, S0_TX_FSR_0);–set adr to read
elsif (step_of_progr = (start_4_stage + 1)) then
cnt := cnt + 1;
SimpleReadReg(cnt);
S0_TX_FSR_contents(15 downto 8) := temp_read_data_08;
elsif (step_of_progr = (start_4_stage + 2)) then
cnt := cnt + 1;
SimpleReadReg(cnt);
S0_TX_FSR_contents(7 downto 0) := temp_read_data_08;
elsif (step_of_progr = (start_4_stage + 3)) then
get_free_size_vect := S0_TX_FSR_contents;
get_free_size := to_integer(unsigned(get_free_size_vect));
if (get_free_size < send_size) then
step_of_progr <= start_4_stage;
else
step_of_progr <= (start_4_stage + 11);
end if;
-- ========= Sn_DIPR = remote_ip; =======
elsif (step_of_progr = (start_4_stage + 11)) then
cnt := cnt + 1;
temp_16 := x"040c";--S0_DIPR(0)
SetAdr_AINC(cnt, temp_16);--set addr to write to
elsif (step_of_progr = (start_4_stage + 12)) then
cnt := cnt + 1;
remote_IP(0) := x"C0";
SimpleWriteReg(cnt, remote_IP(0));
elsif (step_of_progr = (start_4_stage + 13)) then
cnt := cnt + 1;
remote_IP(1) := x"A8";
SimpleWriteReg(cnt, remote_IP(1));
elsif (step_of_progr = (start_4_stage + 14)) then
cnt := cnt + 1;
remote_IP(2) := x"0B";
SimpleWriteReg(cnt, remote_IP(2));
elsif (step_of_progr = (start_4_stage + 15)) then
cnt := cnt + 1;
remote_IP(3) := x"C6";
SimpleWriteReg(cnt, remote_IP(3));
-- ========= Sn_DPORT = remote_port; =======
elsif (step_of_progr = (start_4_stage + 9 + 7)) then
cnt := cnt + 1;
temp_16 := x"0410";--S0_DPORT0
SetAdr_AINC(cnt, temp_16);--set address to write
elsif (step_of_progr = (start_4_stage + 10 + 7)) then
cnt := cnt + 1;
remote_PORT(0) := x"0f";
SimpleWriteReg(cnt, remote_PORT(0));
elsif (step_of_progr = (start_4_stage + 11 + 7)) then
cnt := cnt + 1;
remote_PORT(1) := x"a0";
SimpleWriteReg(cnt, remote_PORT(1));
– ============ REading S0_TX_WR =======
elsif (step_of_progr = (start_4_stage + 12 + 7)) then
cnt := cnt + 1;
SetAdr_AINC(cnt, S0_TX_WR_0);–set address to read
elsif (step_of_progr = (start_4_stage + 13 + 7)) then
cnt := cnt + 1;
SimpleReadReg(cnt);
S0_TX_WR_contents_v(15 downto 8) := temp_read_data_08;
elsif (step_of_progr = (start_4_stage + 14 + 7)) then
cnt := cnt + 1;
SimpleReadReg(cnt);
S0_TX_WR_contents_v(7 downto 0) := temp_read_data_08;
– --==== /* calculate offset address */ ======
elsif (step_of_progr = (start_4_stage + 15 + 7)) then --0x57
cnt := cnt + 1;
temp_16 := x"001B"; – TMSR
SetAdr_AINC(cnt, temp_16);–set address to read
elsif (step_of_progr = (start_4_stage + 16 + 7)) then
cnt := cnt + 1;
SimpleReadReg(cnt); -- this value equals 0x55
elsif (step_of_progr = (start_4_stage + 17 + 7)) then --0x59
get_offset_vect := S0_TX_WR_contents_v and gS0_TX_MASK_vect;
get_offset := to_integer(unsigned(get_offset_vect));
– /* calculate start address(physical address) */ ==
elsif (step_of_progr = (start_4_stage + 18 + 7)) then
gS0_TX_BASE := chip_base_address + TX_memory_base_adr;
get_start_address := gS0_TX_Base + get_offset;
get_start_address_vect := std_logic_vector(to_unsigned(get_start_address, get_start_address_vect’length));
– – /* if overflow socket TX memory */ –
elsif (step_of_progr = (start_4_stage + 19 + 7)) then
step_of_progr <= start_4_stage + 21 + 7;
elsif (step_of_progr = (start_4_stage + 21 + 7)) then
cnt := cnt + 1;
SetAdr_AINC(cnt, get_start_address_vect);--set address to write
elsif (step_of_progr = (start_4_stage + 22 + 7)) then
cnt := cnt + 1;
temp_8 := x"ff";
elsif (step_of_progr = (start_4_stage + 23 + 7)) then
cnt := cnt + 1;
temp_8 := x"ff";
-- increase Sn_TX_WR as length of send_size --
elsif (step_of_progr = (start_4_stage + 24 + 7)) then --0x
S0_TX_WR_contents := to_integer(unsigned(S0_TX_WR_contents_v));
S0_TX_WR_contents := S0_TX_WR_contents + send_size;
S0_TX_WR_contents_v := std_logic_vector(to_unsigned(S0_TX_WR_contents, S0_TX_WR_contents_v'length));
-- write back to Sn_TX_WR--
elsif (step_of_progr = (start_4_stage + 25 + 7)) then
cnt := cnt + 1;
SetAdr_AINC(cnt, S0_TX_WR_0);--set addr to write
elsif (step_of_progr = (start_4_stage + 26 + 7)) then
cnt := cnt + 1;
SimpleWriteReg(cnt, S0_TX_WR_contents_v(15 downto 8));
elsif (step_of_progr = (start_4_stage + 27 + 7)) then
cnt := cnt + 1;
SimpleWriteReg(cnt, S0_TX_WR_contents_v(7 downto 0));
--/* set SEND command */
elsif (step_of_progr = (start_4_stage + 28 + 7)) then
cnt := cnt + 1;
SetAdr_AINC(cnt, S0_CR);--set addr to write
elsif (step_of_progr = (start_4_stage + 29 + 7)) then
cnt := cnt + 1;
SENDd := x"20";
SimpleWriteReg(cnt, SENDd);
–======= Complete Sending? ============
– If (Sn_CR == 0x00) transmission is completed. –
elsif (step_of_progr = (start_4_stage + 30 + 7)) then
cnt := cnt + 1;
SetAdr_AINC(cnt, S0_CR);–set addr to read
elsif (step_of_progr = (start_4_stage + 31 + 7)) then
cnt := cnt + 1;
SimpleReadReg(cnt); -- has to become 0х00
elsif (step_of_progr = (start_4_stage + 32 + 7)) then
if (temp_read_data_08 = x"00") then
step_of_progr <= start_5_stage; -- it is 0х00 indeed
end if;
