Additional Ack
I have w5500 chip with SPI control with my device and implemented TCP Server.
As soon as I received data and set received command it send ack to client.
And with data it send PSH+ACK.
I want to stop this additional ACK send at time or received command.
Please suggest.
Tanmay
I do not think that RECV command triggers W5500 to send any user data within ACK packet.
If you mean that W5500 sends your data with PSH/ACK packet, then it is normal.
Which exactly “additional” ACK? Provide the Wireshark log and point to the entry you want W5500 not to send.
Thanks for prompt response. Find my wire shark packet.
This ACK is related to the RECV command and notifies remote device that it can send more data and scrap data it already sent up to data being acknowledged.
Next packet is triggered by the SEND command, and it contains the user data.
I am afraid you can not combine these packets because one is related to incoming data, and another is related to outgoing data.
Is it possible to response in attached way?
You can achieve it in two ways:
  1. implement your TCP layer using W5500 as IPRAW or MACRAW;
  2. you may not issue RECV command for every received data, but then you risk RX buffer overflow.
In your example above I bet network nodes involved are having TX/RX buffers of 64KB, W5500 can have max 16K. If your software would track buffer replenishment, and issue RECV command only when RX buffer has less than 2*1460 bytes, then you will get similar picture as above with only few “additional” ACKs, but then your application may suffer in performance.
Hello Eugeny,
I have used W5500 in one of my production hardware on site. Now this hardware is getting heating without any reason. I have tried same in my office and come to know that this hardware is heated even with supply. Can you suggest to avoid this heating.
Regards
Tanmay Soni
W5x00 heats in any way, but it should NOT heat if you did not power it on.
If it does not communicate it does not mean chip not checking what is on the wire. So it functions and consumes power, unless you put PHY into power save mode.
