hi, its me again, my question is this: When working with the wiznet in areas where there is satellite internet, the message packets are not sent or received, so I would like to ask you if there is any device configuration that avoids this problem.
Best regards!
Hi Y_Murga, welcome back
Does ‘wiznet in areas where there is satellite internet’ means your device working with a delayed network environment?
Is there a difference in speed between ‘satellite internet’ network and normal wired Ethernet network?
What is the network operating performance of other devices?
If your WIZ107SR operates in TCP mode, TCP timeout will occur in the delayed network, and communication may not be done normally.
